Yesterday my piston fired after the door being open for 5 minutes, except it wasn’t open, it was closed. Seemed to be because of some lag issue. Is there a better way to code this?
The piston is supposed to trigger after the door staying open for 5 minutes.
The door was opened and closed within a few seconds. It seems like the open event lagged and wasn’t registered until after the closed event was registered for some reason. This caused Alexa to tell me the door was open even though it wasn’t. I immediately checked the status of the door in the SmartThings app and it was correctly showing as closed.
(UPLOAD YOUR IMAGE HERE)
9/29/2020, 8:15:21 PM +925ms
+1ms ╔Received event [Home].time = 1601424921608 with a delay of 317ms
+141ms ║Runtime (37157 bytes) successfully initialized in 7ms (v0.3.110.20191009) (140ms)
+1205ms ║║Executed [Echo - Bedroom].playTextAndResume (1043ms)
+1542ms ║║Executed [Echo - Kitchen].playTextAndResume (334ms)
+1828ms ║║Executed [Echo - Office].playTextAndResume (283ms)
+1831ms ║╚Execution stage complete. (1689ms)
+1832ms ╚Event processed successfully (1832ms)
9/29/2020, 8:10:21 PM +522ms
+2ms ╔Received event [Front Door].contact = open with a delay of 6277ms
+76ms ║Runtime (37160 bytes) successfully initialized in 6ms (v0.3.110.20191009) (73ms)
+78ms ║╔Execution stage started
+89ms ║╚Execution stage complete. (12ms)
+91ms ║Setting up scheduled job for Tue, Sep 29 2020 @ 8:15:21 PM EDT (in 299.996s)
+97ms ╚Event processed successfully (97ms)
9/29/2020, 8:10:20 PM +900ms
+1ms ╔Received event [Front Door].contact = closed with a delay of 74ms
+60ms ║Runtime (37160 bytes) successfully initialized in 4ms (v0.3.110.20191009) (59ms)
+61ms ║╔Execution stage started
+70ms ║╚Execution stage complete. (10ms)
+71ms ╚Event processed successfully (71ms)
