Door Locked by Keypad, help please?
I am trying to do a routine a minute after currentEventValue changes to keypadLocked.
The problem here is that value only stays keypadLocked for a few seconds then it changes to locked and the piston stops running.
The only condition here is that it has to stay locked for 1 minute because I may have forgotten something before leaving the house.
What’s the best way to form this piston?
try: if (status changes to keypadLocked) or (status is locked). Then it will trigger off the change but the second condition will continue execution as long as it stays locked.
Thanks man
