(The piston is contacting/notifying me every single time the front door sensor is closed.)
(I want the piston to notify me only when the front door sensor is closed, BUT only after it has been opened for 90 seconds or more.)
(It is contacting me if the front door sensor has been opened for 90 seconds. So that part is working fine. And it’s also contacting me after the door closes after 90 seconds too.)
( 3/23/2018, 3:20:48 PM +308ms
+3ms ╔Received event [Home].test = 1521836448303 with a delay of 1ms
+150ms ║RunTime Analysis CS > 22ms > PS > 103ms > PE > 28ms > CE
+158ms ║Runtime (41811 bytes) successfully initialized in 103ms (v0.3.000.20180224) (151ms)
+161ms ║╔Execution stage started
+202ms ║║Comparison (enum) closed stays (string) open = false (4ms)
+205ms ║║Cancelling any timed trigger schedules for condition 4
+207ms ║║Cancelling statement #4’s schedules…
+208ms ║║Condition #4 evaluated false (31ms)
+209ms ║║Condition group #1 evaluated false (state did not change) (33ms)
+227ms ║║Cancelling condition #13’s schedules…
+228ms ║║Condition #13 evaluated false (15ms)
+229ms ║║Cancelling condition #11’s schedules…
+230ms ║║Condition group #11 evaluated false (state changed) (17ms)
+238ms ║╚Execution stage complete. (79ms)
+243ms ╚Event processed successfully (243ms))
