I have pistons that are triggered by my front door being unlocked by specific codes. They all stopped working recently, but had been working fine.
For the piston I’ve snapshotted, when my housekeeper arrives and enters the front door via her code, a few things happen including a mode change,
Now, according to the log, the front door isn’t being unlocked as far as I can tell?
| +2ms | ╔Received event [Front Door Lock].lock = unlocked with a delay of 717ms |
| +329ms | ║RunTime Analysis CS > 19ms > PS > 82ms > PE > 227ms > CE |
| +338ms | ║Runtime (41617 bytes) successfully initialized in 82ms (v0.2.0ff.20171129) (336ms) |
| +339ms | ║╔Execution stage started |
| +348ms | ║║Comparison (enum) unlocked gets (string) unlocked = false (0ms) |
| +349ms | ║║Condition #3 evaluated false (5ms) |
| +350ms | ║║Condition group #1 evaluated false (state did not change) (6ms) |
| +352ms | ║╚Execution stage complete. (13ms) |
| +360ms | ╚Event processed successfully (360ms) |
I have other pistons that trigger on door unlock codes. My house changes to AirBnB mode when its not in AirBnB mode and the front door is unlocked with an AirBnB code. That one stopped working too. I made a test piston where I set it so that when the door got unlocked by any code (I used select all) I was to get a notification, and that didn’t work either. I changed said test piston so that instead of triggering on any unlock code, it was just triggered when the door got unlocked, and that worked, so I think the problem is with the “gets unlocked by code” function?
