I have a front door lock pester piston that sends a text and an audible “spoken” alert over google home when someone forgets to lock the door, and repeats every 5 minutes until someone locks the door.
That works, but I want to have the text message go out to the last person that unlocked the door based on which code was used to unlock the door (when possible)
When code 3 is used, and the door remains unlocked for the set time, The 2nd if statement is running, but not the first one as I intend, however {$args.usedCode} is swapping with “3” in the text message (line 53)
**4) Post a Green Snapshot of the piston)
Thank you.
