Does anyone know if it’s at all possible to modify a basic st Alarm type handler so the commands (off,strobe,both & siren) can have different names?
I know the labels & icons can be modified to show different things but it’s the actual command names which would show in WC that I’m interested in.
DTH Modification question
          Baz2473
          c1arkbar
      I would say to create a new DTH from template using the alarm one you currently have and see if you can successfully do it. So I would say it’s possible sure
          Baz2473
      I’ve just given that a try and unfortunately that doesn’t seem to work either? But thanks for the suggestion.
