This one is for the proud dullards and simpletons, no coding, messing with websites, developers options, Windows/Raspberry Pi’s, IFTTT, custom scripts on routers, Get Requests, or paid for service necessary. I’ve read every thread on this subject and it required a high level of coding experience to accomplish.
This is a simple DTH from 2015 and thanks to WebCoRE you can poll your IP address as often or as little as you like.
All credit for the DTH goes to patrickstuart.com
* ps_GetPublicIP
* Copyright 2014 [email protected]
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
preferences {
metadata {
definition (name: "ps_GetPublicIP", namespace: "ps", author: "[email protected]") {
capability "Polling"
attribute "publicIp", "string"
simulator {
tiles {
valueTile("publicIp", "device.publicIp", inactiveLabel: false, decoration: "flat", columns:2) {
state "default", label:'${currentValue}', unit:"Public IP"
standardTile("refresh", "device.poll", inactiveLabel: false, decoration: "flat") {
state "default", action:"polling.poll", icon:"st.secondary.refresh"
main "publicIp"
details(["publicIp", "refresh"])
// parse events into attributes
def parse(String description) {
log.debug "Parsing '${description}'"
def map = stringToMap(description)
def bodyString = new String(map.body.decodeBase64())
log.debug bodyString
def body = new XmlSlurper().parseText(bodyString)
log.debug body
def publicip2 = body.toString().replace("Current IP CheckCurrent IP Address: ","")
log.debug publicip2
sendEvent(name: 'publicIp', value: publicip2)
// handle commands
def poll() {
log.debug "Executing 'poll'"
login()
def login() {
def method = "GET"
def host = "216.146.38.70"
def hosthex = convertIPtoHex(host)
def porthex = convertPortToHex(80)
device.deviceNetworkId = "$hosthex:$porthex"
def headers = [:]
headers.put("HOST", "$host:80")
def path = "/"
def hubAction = new physicalgraph.device.HubAction(
method: method,
path: path,
headers: headers
log.debug hubAction
hubAction
private String convertIPtoHex(ipAddress) {
String hex = ipAddress.tokenize( '.' ).collect { String.format( '%02x', it.toInteger() ) }.join()
log.debug "IP address entered is $ipAddress and the converted hex code is $hex"
return hex
private String convertPortToHex(port) {
String hexport = port.toString().format( '%04x', port.toInteger() )
log.debug hexport
return hexport
private Integer convertHexToInt(hex) {
Integer.parseInt(hex,16)
private String convertHexToIP(hex) {
log.debug("Convert hex to ip: $hex")
[convertHexToInt(hex[0..1]),convertHexToInt(hex[2..3]),convertHexToInt(hex[4..5]),convertHexToInt(hex[6..7])].join(".")
private getHostAddress() {
def parts = device.deviceNetworkId.split(":")
log.debug device.deviceNetworkId
def ip = convertHexToIP(parts[0])
def port = convertHexToInt(parts[1])
return ip + ":" + port
