the announcement is not quite working correctly
when a user(s) leaves or arrives the piston should be able to fire determine who left or arrived then send a get request based on the user/users seen.
I based the design off this thread discussion Arrival of people including multiple people at once
the get request is only firing for 1 user and not for multiple and tends to repeat only for the single user
(UPLOAD YOUR IMAGE HERE)
9/15/2020, 8:28:32 PM +379ms
+0ms ╔Received event [Home].time = 1600216106740 with a delay of 5639ms
+255ms ║RunTime Analysis CS > 49ms > PS > 137ms > PE > 69ms > CE
+258ms ║Runtime (58958 bytes) successfully initialized in 137ms (v0.3.110.20191009) (257ms)
+259ms ║╔Execution stage started
+284ms ║║Executed virtual command setVariable (3ms)
+289ms ║║Comparison (time) 73712666 happens_daily_at (datetime) 1600211272125 = false (0ms)
+291ms ║║Condition #26 evaluated false (4ms)
+292ms ║║Cancelling statement #26's schedules...
+295ms ║║Requesting time schedule wake up at Wed, Sep 16 2020 @ 7:08:07 PM EDT
+298ms ║║Condition group #25 evaluated false (state did not change) (12ms)
+304ms ║║Comparison (integer) 1 is_greater_than (integer) 0 = true (1ms)
+305ms ║║Cancelling condition #31's schedules...
+306ms ║║Condition #31 evaluated true (6ms)
+307ms ║║Cancelling condition #30's schedules...
+308ms ║║Condition group #30 evaluated true (state changed) (8ms)
+311ms ║║Cancelling statement #32's schedules...
+325ms ║║Calculating (decimal) 0.0 - (decimal) 1.0 >> (decimal) -1.0
+329ms ║║Executed virtual command setVariable (2ms)
+346ms ║║Calculating (integer) 0 - (integer) -1 >> (integer) 1
+449ms ║║Calculating (integer) 1 - (integer) 2 >> (integer) -1
+455ms ║║Calculating (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 + (string) and >> (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and
+460ms ║║Calculating (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and + (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 >> (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and java.lang.StringIndexOutOfBoundsException: String index out of range: -1
+464ms ║║Calculating (integer) -1 > (integer) 0 >> (boolean) false
+470ms ║║Executed virtual command setVariable (3ms)
+475ms ║║Comparison (string) is (string) Mom = false (1ms)
+477ms ║║Condition #36 evaluated false (5ms)
+478ms ║║Condition group #35 evaluated false (state did not change) (5ms)
+483ms ║║Comparison (string) is (string) Papa = false (1ms)
+484ms ║║Condition #42 evaluated false (4ms)
+485ms ║║Condition group #41 evaluated false (state did not change) (5ms)
+487ms ║║Cancelling statement #47's schedules...
+493ms ║║Executed virtual command setVariable (3ms)
+497ms ║║Executed virtual command setVariable (2ms)
+500ms ║╚Execution stage complete. (241ms)
+501ms ║Setting up scheduled job for Wed, Sep 16 2020 @ 7:08:07 PM EDT (in 81574.246s)
+507ms ╚Event processed successfully (507ms)
9/15/2020, 8:28:18 PM +506ms
+2ms ╔Received event [Front Door Sensor].contact = closed with a delay of 86ms
+183ms ║RunTime Analysis CS > 21ms > PS > 98ms > PE > 64ms > CE
+187ms ║Runtime (58967 bytes) successfully initialized in 98ms (v0.3.110.20191009) (184ms)
+188ms ║╔Execution stage started
+196ms ║║Calculating (datetime) 1600216098699 - (datetime) 1600211272125 >> (datetime) 4826574
+199ms ║║Comparison (datetime) 4826574 is_greater_than (integer) 350000 = true (1ms)
+200ms ║║Condition #2 evaluated true (9ms)
+201ms ║║Condition group #1 evaluated true (state did not change) (10ms)
+203ms ║║Cancelling statement #3's schedules...
+208ms ║║Executed virtual command setVariable (3ms)
+213ms ║║Executed virtual command setVariable (3ms)
+222ms ║║Comparison (enum) closed changes_to (string) closed = true (1ms)
+223ms ║║Cancelling condition #19's schedules...
+224ms ║║Condition #19 evaluated true (6ms)
+225ms ║║Cancelling condition #18's schedules...
+226ms ║║Condition group #18 evaluated true (state changed) (9ms)
+227ms ║║Cancelling condition #17's schedules...
+228ms ║║Condition group #17 evaluated true (state changed) (10ms)
+230ms ║║Cancelling statement #22's schedules...
+233ms ║║Executed virtual command wait (0ms)
+234ms ║║Requesting a wake up for Tue, Sep 15 2020 @ 8:28:26 PM EDT (in 8.0s)
+238ms ║╚Execution stage complete. (51ms)
+240ms ║Setting up scheduled job for Tue, Sep 15 2020 @ 8:28:26 PM EDT (in 7.995s), with 1 more job pending
+247ms ╚Event processed successfully (247ms)
9/15/2020, 8:28:14 PM +790ms
+1ms ╔Received event [Front Door Sensor].contact = open with a delay of 66ms
+183ms ║RunTime Analysis CS > 17ms > PS > 105ms > PE > 62ms > CE
+186ms ║Runtime (58964 bytes) successfully initialized in 105ms (v0.3.110.20191009) (184ms)
+187ms ║╔Execution stage started
+195ms ║║Calculating (datetime) 1600216094982 - (datetime) 1600211272125 >> (datetime) 4822857
+199ms ║║Comparison (datetime) 4822857 is_greater_than (integer) 350000 = true (1ms)
+201ms ║║Condition group #1 evaluated true (state did not change) (9ms)
+207ms ║║Executed virtual command setVariable (3ms)
+212ms ║║Executed virtual command setVariable (3ms)
+309ms ║║Comparison (enum) open changes_to (string) closed = false (1ms)
+311ms ║║Cancelling condition #19's schedules...
+312ms ║║Condition #19 evaluated false (95ms)
+321ms ║║Comparison (enum) is (string) inactive = false (1ms)
+322ms ║║Condition #20 evaluated false (10ms)
+323ms ║║Cancelling condition #18's schedules...
+324ms ║║Condition group #18 evaluated false (state changed) (108ms)
+329ms ║║Comparison (boolean) true is (boolean) false = false (1ms)
+331ms ║║Condition #21 evaluated false (5ms)
+332ms ║║Cancelling condition #17's schedules...
+332ms ║║Condition group #17 evaluated false (state changed) (117ms)
+337ms ║║Comparison (time) 73695125 happens_daily_at (datetime) 1600211272125 = false (0ms)
+339ms ║║Condition #26 evaluated false (3ms)
+339ms ║║Cancelling statement #26's schedules...
+342ms ║║Requesting time schedule wake up at Wed, Sep 16 2020 @ 7:08:07 PM EDT
+345ms ║║Condition group #25 evaluated false (state did not change) (10ms)
+350ms ║║Comparison (integer) 0 is_greater_than (integer) 0 = false (1ms)
+351ms ║║Cancelling condition #31's schedules...
+352ms ║║Condition #31 evaluated false (5ms)
+353ms ║║Cancelling condition #30's schedules...
+353ms ║║Condition group #30 evaluated false (state changed) (7ms)
+359ms ║║Comparison (string) is (string) Mom = false (1ms)
+360ms ║║Condition #36 evaluated false (4ms)
+361ms ║║Condition group #35 evaluated false (state did not change) (5ms)
+366ms ║║Comparison (string) is (string) Papa = false (1ms)
+367ms ║║Condition #42 evaluated false (4ms)
+368ms ║║Condition group #41 evaluated false (state did not change) (5ms)
+370ms ║║Cancelling statement #47's schedules...
+374ms ║║Executed virtual command setVariable (2ms)
+379ms ║║Executed virtual command setVariable (3ms)
+382ms ║╚Execution stage complete. (194ms)
+383ms ║Setting up scheduled job for Wed, Sep 16 2020 @ 7:08:07 PM EDT (in 81591.953s)
+393ms ╚Event processed successfully (393ms)
9/15/2020, 7:45:48 PM +745ms
+1ms ╔Received event [Home].time = 1600213549451 with a delay of -706ms
+212ms ║RunTime Analysis CS > 21ms > PS > 124ms > PE > 67ms > CE
+216ms ║Runtime (58958 bytes) successfully initialized in 124ms (v0.3.110.20191009) (214ms)
+217ms ║╔Execution stage started
+241ms ║║Executed virtual command setVariable (3ms)
+247ms ║║Comparison (time) 71148989 happens_daily_at (datetime) 1600211272125 = false (1ms)
+248ms ║║Condition #26 evaluated false (4ms)
+250ms ║║Cancelling statement #26's schedules...
+253ms ║║Requesting time schedule wake up at Wed, Sep 16 2020 @ 7:08:07 PM EDT
+255ms ║║Condition group #25 evaluated false (state did not change) (11ms)
+260ms ║║Comparison (integer) 1 is_greater_than (integer) 0 = true (1ms)
+262ms ║║Cancelling condition #31's schedules...
+263ms ║║Condition #31 evaluated true (6ms)
+264ms ║║Cancelling condition #30's schedules...
+265ms ║║Condition group #30 evaluated true (state changed) (7ms)
+267ms ║║Cancelling statement #32's schedules...
+278ms ║║Calculating (decimal) 0.0 - (decimal) 1.0 >> (decimal) -1.0
+284ms ║║Executed virtual command setVariable (2ms)
+302ms ║║Calculating (integer) 0 - (integer) -1 >> (integer) 1
+305ms ║║Calculating (integer) 1 - (integer) 2 >> (integer) -1
+313ms ║║Calculating (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 + (string) and >> (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and
+317ms ║║Calculating (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and + (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 >> (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and java.lang.StringIndexOutOfBoundsException: String index out of range: -1
+320ms ║║Calculating (integer) -1 > (integer) 0 >> (boolean) false
+327ms ║║Executed virtual command setVariable (3ms)
+333ms ║║Comparison (string) is (string) Mom = false (1ms)
+335ms ║║Condition #36 evaluated false (5ms)
+336ms ║║Condition group #35 evaluated false (state did not change) (6ms)
+341ms ║║Comparison (string) is (string) Papa = false (1ms)
+342ms ║║Condition #42 evaluated false (4ms)
+343ms ║║Condition group #41 evaluated false (state did not change) (5ms)
+346ms ║║Cancelling statement #47's schedules...
+351ms ║║Executed virtual command setVariable (3ms)
+357ms ║║Executed virtual command setVariable (4ms)
+359ms ║╚Execution stage complete. (143ms)
+361ms ║Setting up scheduled job for Wed, Sep 16 2020 @ 7:08:07 PM EDT (in 84138.02s)
+412ms ╚Event processed successfully (412ms)
9/15/2020, 7:45:41 PM +243ms
+0ms ╔Received event [Front Door Sensor].contact = closed with a delay of 50ms
+156ms ║RunTime Analysis CS > 17ms > PS > 75ms > PE > 65ms > CE
+159ms ║Runtime (58967 bytes) successfully initialized in 75ms (v0.3.110.20191009) (158ms)
+160ms ║╔Execution stage started
+169ms ║║Calculating (datetime) 1600213541408 - (datetime) 1600211272125 >> (datetime) 2269283
+172ms ║║Comparison (datetime) 2269283 is_greater_than (integer) 350000 = true (1ms)
+173ms ║║Condition #2 evaluated true (9ms)
+174ms ║║Condition group #1 evaluated true (state did not change) (10ms)
+177ms ║║Cancelling statement #3's schedules...
+181ms ║║Executed virtual command setVariable (3ms)
+186ms ║║Executed virtual command setVariable (2ms)
+195ms ║║Comparison (enum) closed changes_to (string) closed = true (1ms)
+197ms ║║Cancelling condition #19's schedules...
+198ms ║║Condition #19 evaluated true (6ms)
+199ms ║║Cancelling condition #18's schedules...
+200ms ║║Condition group #18 evaluated true (state changed) (9ms)
+201ms ║║Cancelling condition #17's schedules...
+201ms ║║Condition group #17 evaluated true (state changed) (11ms)
+203ms ║║Cancelling statement #22's schedules...
+206ms ║║Executed virtual command wait (0ms)
+208ms ║║Requesting a wake up for Tue, Sep 15 2020 @ 7:45:49 PM EDT (in 8.0s)
+212ms ║╚Execution stage complete. (52ms)
+214ms ║Setting up scheduled job for Tue, Sep 15 2020 @ 7:45:49 PM EDT (in 7.995s), with 1 more job pending
+227ms ╚Event processed successfully (227ms)
9/15/2020, 7:45:38 PM +546ms
+1ms ╔Received event [Front Door Sensor].contact = open with a delay of 77ms
+190ms ║RunTime Analysis CS > 19ms > PS > 107ms > PE > 64ms > CE
+194ms ║Runtime (58964 bytes) successfully initialized in 107ms (v0.3.110.20191009) (191ms)
+194ms ║╔Execution stage started
+203ms ║║Calculating (datetime) 1600213538746 - (datetime) 1600211272125 >> (datetime) 2266621
+207ms ║║Comparison (datetime) 2266621 is_greater_than (integer) 350000 = true (2ms)
+208ms ║║Condition #2 evaluated true (9ms)
+209ms ║║Condition group #1 evaluated true (state did not change) (11ms)
+211ms ║║Cancelling statement #3's schedules...
+216ms ║║Executed virtual command setVariable (3ms)
+222ms ║║Executed virtual command setVariable (3ms)
+231ms ║║Comparison (enum) open changes_to (string) closed = false (1ms)
+232ms ║║Cancelling condition #19's schedules...
+233ms ║║Condition #19 evaluated false (7ms)
+242ms ║║Comparison (enum) is (string) inactive = false (1ms)
+244ms ║║Condition #20 evaluated false (10ms)
+245ms ║║Cancelling condition #18's schedules...
+246ms ║║Condition group #18 evaluated false (state changed) (19ms)
+251ms ║║Comparison (boolean) true is (boolean) false = false (1ms)
+252ms ║║Condition #21 evaluated false (6ms)
+253ms ║║Cancelling condition #17's schedules...
+254ms ║║Condition group #17 evaluated false (state changed) (28ms)
+260ms ║║Comparison (time) 71138803 happens_daily_at (datetime) 1600211272125 = false (0ms)
+261ms ║║Condition #26 evaluated false (4ms)
+262ms ║║Cancelling statement #26's schedules...
+265ms ║║Requesting time schedule wake up at Wed, Sep 16 2020 @ 7:08:07 PM EDT
+267ms ║║Condition group #25 evaluated false (state did not change) (11ms)
+273ms ║║Comparison (integer) 0 is_greater_than (integer) 0 = false (1ms)
+274ms ║║Cancelling condition #31's schedules...
+275ms ║║Condition #31 evaluated false (6ms)
+276ms ║║Cancelling condition #30's schedules...
+277ms ║║Condition group #30 evaluated false (state changed) (7ms)
+282ms ║║Comparison (string) is (string) Mom = false (1ms)
+284ms ║║Condition #36 evaluated false (4ms)
+285ms ║║Condition group #35 evaluated false (state did not change) (5ms)
+290ms ║║Comparison (string) is (string) Papa = false (2ms)
+291ms ║║Condition #42 evaluated false (4ms)
+292ms ║║Condition group #41 evaluated false (state did not change) (5ms)
+294ms ║║Cancelling statement #47's schedules...
+299ms ║║Executed virtual command setVariable (3ms)
+304ms ║║Executed virtual command setVariable (2ms)
+307ms ║╚Execution stage complete. (112ms)
+308ms ║Setting up scheduled job for Wed, Sep 16 2020 @ 7:08:07 PM EDT (in 84148.272s)
+317ms ╚Event processed successfully (317ms)
9/15/2020, 7:44:32 PM +140ms
+1ms ╔Received event [Home].time = 1600213473037 with a delay of -897ms
+224ms ║RunTime Analysis CS > 26ms > PS > 133ms > PE > 65ms > CE
+228ms ║Runtime (58958 bytes) successfully initialized in 133ms (v0.3.110.20191009) (226ms)
+229ms ║╔Execution stage started
+253ms ║║Executed virtual command setVariable (4ms)
+259ms ║║Comparison (time) 71072396 happens_daily_at (datetime) 1600211272125 = false (0ms)
+260ms ║║Condition #26 evaluated false (4ms)
+261ms ║║Cancelling statement #26's schedules...
+264ms ║║Requesting time schedule wake up at Wed, Sep 16 2020 @ 7:08:07 PM EDT
+266ms ║║Condition group #25 evaluated false (state did not change) (10ms)
+272ms ║║Comparison (integer) 1 is_greater_than (integer) 0 = true (2ms)
+273ms ║║Cancelling condition #31's schedules...
+274ms ║║Condition #31 evaluated true (5ms)
+275ms ║║Cancelling condition #30's schedules...
+276ms ║║Condition group #30 evaluated true (state changed) (8ms)
+278ms ║║Cancelling statement #32's schedules...
+288ms ║║Calculating (decimal) 0.0 - (decimal) 1.0 >> (decimal) -1.0
+294ms ║║Executed virtual command setVariable (4ms)
+311ms ║║Calculating (integer) 0 - (integer) -1 >> (integer) 1
+314ms ║║Calculating (integer) 1 - (integer) 2 >> (integer) -1
+320ms ║║Calculating (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 + (string) and >> (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and
+323ms ║║Calculating (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and + (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 >> (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and java.lang.StringIndexOutOfBoundsException: String index out of range: -1
+327ms ║║Calculating (integer) -1 > (integer) 0 >> (boolean) false
+332ms ║║Executed virtual command setVariable (3ms)
+337ms ║║Comparison (string) is (string) Mom = false (1ms)
+339ms ║║Condition #36 evaluated false (5ms)
+340ms ║║Condition group #35 evaluated false (state did not change) (6ms)
+346ms ║║Comparison (string) is (string) Papa = false (1ms)
+347ms ║║Condition #42 evaluated false (5ms)
+348ms ║║Condition group #41 evaluated false (state did not change) (6ms)
+351ms ║║Cancelling statement #47's schedules...
+356ms ║║Executed virtual command setVariable (3ms)
+361ms ║║Executed virtual command setVariable (3ms)
+363ms ║╚Execution stage complete. (135ms)
+365ms ║Setting up scheduled job for Wed, Sep 16 2020 @ 7:08:07 PM EDT (in 84214.621s)
+370ms ╚Event processed successfully (370ms)
9/15/2020, 7:44:24 PM +804ms
+1ms ╔Received event [Front Door Sensor].contact = closed with a delay of 69ms
+183ms ║RunTime Analysis CS > 20ms > PS > 100ms > PE > 62ms > CE
+186ms ║Runtime (58969 bytes) successfully initialized in 100ms (v0.3.110.20191009) (184ms)
+195ms ║║Calculating (datetime) 1600213464996 - (datetime) 1600211272125 >> (datetime) 2192871
+198ms ║║Comparison (datetime) 2192871 is_greater_than (integer) 350000 = true (1ms)
+200ms ║║Condition #2 evaluated true (8ms)
+200ms ║║Condition group #1 evaluated true (state did not change) (10ms)
+202ms ║║Cancelling statement #3's schedules...
+213ms ║║Executed virtual command setVariable (4ms)
+222ms ║║Comparison (enum) closed changes_to (string) closed = true (0ms)
+224ms ║║Condition #19 evaluated true (7ms)
+226ms ║║Condition group #18 evaluated true (state changed) (8ms)
+226ms ║║Cancelling condition #17's schedules...
+227ms ║║Condition group #17 evaluated true (state changed) (10ms)
+229ms ║║Cancelling statement #22's schedules...
+232ms ║║Executed virtual command wait (1ms)
+233ms ║║Requesting a wake up for Tue, Sep 15 2020 @ 7:44:33 PM EDT (in 8.0s)
+237ms ║╚Execution stage complete. (51ms)
+239ms ║Setting up scheduled job for Tue, Sep 15 2020 @ 7:44:33 PM EDT (in 7.995s), with 1 more job pending
+275ms ╚Event processed successfully (275ms)
9/15/2020, 7:44:22 PM +568ms
+1ms ╔Received event [Front Door Sensor].contact = open with a delay of 55ms
+149ms ║RunTime Analysis CS > 14ms > PS > 75ms > PE > 60ms > CE
+152ms ║Runtime (58962 bytes) successfully initialized in 75ms (v0.3.110.20191009) (150ms)
+153ms ║╔Execution stage started
+161ms ║║Calculating (datetime) 1600213462726 - (datetime) 1600211272125 >> (datetime) 2190601
+164ms ║║Comparison (datetime) 2190601 is_greater_than (integer) 350000 = true (1ms)
+165ms ║║Condition #2 evaluated true (8ms)
+166ms ║║Condition group #1 evaluated true (state did not change) (9ms)
+168ms ║║Cancelling statement #3's schedules...
+172ms ║║Executed virtual command setVariable (2ms)
+176ms ║║Executed virtual command setVariable (2ms)
+185ms ║║Comparison (enum) open changes_to (string) closed = false (1ms)
+186ms ║║Cancelling condition #19's schedules...
+187ms ║║Condition #19 evaluated false (6ms)
+197ms ║║Comparison (enum) is (string) inactive = false (2ms)
+198ms ║║Condition #20 evaluated false (10ms)
+200ms ║║Condition group #18 evaluated false (state changed) (19ms)
+205ms ║║Comparison (boolean) true is (boolean) false = false (1ms)
+206ms ║║Condition #21 evaluated false (5ms)
+207ms ║║Cancelling condition #17's schedules...
+208ms ║║Condition group #17 evaluated false (state changed) (28ms)
+213ms ║║Comparison (time) 71062778 happens_daily_at (datetime) 1600211272125 = false (1ms)
+214ms ║║Condition #26 evaluated false (4ms)
+215ms ║║Cancelling statement #26's schedules...
+218ms ║║Requesting time schedule wake up at Wed, Sep 16 2020 @ 7:08:07 PM EDT
+220ms ║║Condition group #25 evaluated false (state did not change) (10ms)
+225ms ║║Comparison (integer) 0 is_greater_than (integer) 0 = false (2ms)
+226ms ║║Cancelling condition #31's schedules...
+227ms ║║Condition #31 evaluated false (5ms)
+228ms ║║Cancelling condition #30's schedules...
+229ms ║║Condition group #30 evaluated false (state changed) (6ms)
+233ms ║║Comparison (string) is (string) Mom = false (1ms)
+235ms ║║Condition #36 evaluated false (3ms)
+236ms ║║Condition group #35 evaluated false (state did not change) (5ms)
+240ms ║║Comparison (string) is (string) Papa = false (1ms)
+242ms ║║Condition #42 evaluated false (3ms)
+242ms ║║Condition group #41 evaluated false (state did not change) (5ms)
+245ms ║║Cancelling statement #47's schedules...
+249ms ║║Executed virtual command setVariable (3ms)
+253ms ║║Executed virtual command setVariable (2ms)
+255ms ║╚Execution stage complete. (102ms)
+257ms ║Setting up scheduled job for Wed, Sep 16 2020 @ 7:08:07 PM EDT (in 84224.301s)
+267ms ╚Event processed successfully (267ms)
9/15/2020, 7:44:08 PM +234ms
+0ms ╔Received event [Home].time = 1600213449210 with a delay of -976ms
+261ms ║RunTime Analysis CS > 42ms > PS > 143ms > PE > 75ms > CE
+264ms ║Runtime (58958 bytes) successfully initialized in 143ms (v0.3.110.20191009) (263ms)
+266ms ║╔Execution stage started
+297ms ║║Executed virtual command setVariable (3ms)
+304ms ║║Comparison (time) 71048535 happens_daily_at (datetime) 1600211272125 = false (0ms)
+306ms ║║Condition #26 evaluated false (5ms)
+307ms ║║Cancelling statement #26's schedules...
+311ms ║║Requesting time schedule wake up at Wed, Sep 16 2020 @ 7:08:07 PM EDT
+313ms ║║Condition group #25 evaluated false (state did not change) (13ms)
+320ms ║║Comparison (integer) 1 is_greater_than (integer) 0 = true (1ms)
+322ms ║║Cancelling condition #31's schedules...
+323ms ║║Condition #31 evaluated true (6ms)
+325ms ║║Cancelling condition #30's schedules...
+326ms ║║Condition group #30 evaluated true (state changed) (9ms)
+328ms ║║Cancelling statement #32's schedules...
+342ms ║║Calculating (decimal) 0.0 - (decimal) 1.0 >> (decimal) -1.0
+349ms ║║Executed virtual command setVariable (4ms)
+372ms ║║Calculating (integer) 0 - (integer) -1 >> (integer) 1
+375ms ║║Calculating (integer) 1 - (integer) 2 >> (integer) -1
+384ms ║║Calculating (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 + (string) and >> (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and
+389ms ║║Calculating (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and + (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 >> (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and java.lang.StringIndexOutOfBoundsException: String index out of range: -1
+393ms ║║Calculating (integer) -1 > (integer) 0 >> (boolean) false
+400ms ║║Executed virtual command setVariable (3ms)
+405ms ║║Comparison (string) is (string) Mom = false (1ms)
+407ms ║║Condition #36 evaluated false (5ms)
+408ms ║║Condition group #35 evaluated false (state did not change) (6ms)
+414ms ║║Comparison (string) is (string) Papa = false (1ms)
+416ms ║║Condition #42 evaluated false (5ms)
