Echo Speaks Issue
Hi all, I used to have a simple piston running that on a Thursday once the Bedtime routine is run, Echo speaks “Recycling” but for some reason this has stopped.
For some reason, the Alexa just no longer speaks anything?
Have you tried creating a bare bones piston to test if Echo speaks is still working? If not, you might have to check in the ST Echo Speaks thread for troubleshooting to see if your login cookie is still valid. Sometimes, just logging back in should do the trick.
