I am trying to create a notification when any of my entry doors are left open for 5 minutes on my echo devices. I know Echo Speaks is working because I can trigger announcements from the ST app so I think it is something with my WebCore code.
If any of the entry door contacts are open for more than 5 minutes it should announce on my echo that the door is open. I am only use one door and one echo as proof of concept, but I am having trouble getting it to work.
I see the contact open, but nothing is coming out of my echo.
3/16/2020, 11:20:46 AM +479ms
+1ms âReceived event [Front Door].contact = closed with a delay of 97ms
+94ms âRunTime Analysis CS > 24ms > PS > 59ms > PE > 11ms > CE
+97ms âRuntime (37613 bytes) successfully initialized in 59ms (v0.3.110.20191009) (95ms)
+98ms ââExecution stage started
+105ms ââComparison (enum) closed changes_to (string) open = false (1ms)
+106ms ââCancelling condition #2's schedules...
+107ms ââCondition #2 evaluated false (5ms)
+108ms ââCancelling condition #1's schedules...
+109ms ââCondition group #1 evaluated false (state changed) (7ms)
+111ms ââExecution stage complete. (13ms)
+112ms âEvent processed successfully (112ms)
3/16/2020, 11:20:40 AM +276ms
+2ms âReceived event [Front Door].contact = open with a delay of 106ms
+102ms âRunTime Analysis CS > 22ms > PS > 63ms > PE > 16ms > CE
+105ms âRuntime (37620 bytes) successfully initialized in 63ms (v0.3.110.20191009) (102ms)
+106ms ââExecution stage started
+114ms ââComparison (enum) open changes_to (string) open = true (1ms)
+116ms ââCancelling condition #2's schedules...
+117ms ââCondition #2 evaluated true (5ms)
+118ms ââCancelling condition #1's schedules...
+118ms ââCondition group #1 evaluated true (state changed) (7ms)
+121ms ââCancelling statement #3's schedules...
+204ms ââExecuted physical command [Echo - Allen's 2nd Echo Show].setVolumeAndSpeak([80, Front door is open]) (76ms)
+205ms ââExecuted [Echo - Allen's 2nd Echo Show].setVolumeAndSpeak (78ms)
+231ms ââExecuted physical command [Echo - Allen's 2nd Echo Show].playText([The front door is open]) (22ms)
+232ms ââExecuted [Echo - Allen's 2nd Echo Show].playText (24ms)
+235ms ââExecution stage complete. (129ms)
+236ms âEvent processed successfully (236ms)
