When I run my simple Piston it does not seem to turn on/off the light switch correctly. Sometimes it will turn the switch ON if the Switch was on the OFF position for the first run… and Visa Verca
I am assuming it should turn the switch to the On/Off position using toggle
It sometimes toggles the first time but attempts after does not work.
