First piston - I’m keen to see if you can edit pistons manually? i’d find this a lot faster (i.e edit the statements directly without the popup? I just can’t work out how to do this
Also when using pop up restrictions entry - how do you enter location = mode? i cannot find it anywhere?
Sorry these are such basic questions. once i get edit mode i should be able to go crazy
as above
as above
thank you
