This one controls my electric towel warmer. Only comes on if the room is under a certain temp and if someone home and at certain times of day.
Electric Towel Warmer Temperature,Time and SHM dependant
Baz2473
Einars
I have something similar.
One twist i got on it is that i turn i off ater 3 hrs no matter how it is switched on instead of a from time to time.
So when i manualy switch it on it turns of after 3 hrs also.
Baz2473
Great idea, not sure I’ll implement that in mine because my towel Warmer is very close to the temperature sensor on the st motion sensor so once the temp goes above 18° it shuts off anyway. But worth considering your suggestion.
Thanks.
Baz2473
Also I have the timings set for roughly the times we tend to use the bathroom and require towels.
Einars
Same as me, one for weekdays, and one for weekend.
Works like a charm
And you know i am a cold person.
EDIT
Why, why, why, do you get up at that time on sundays? hehe
