"Empty device list" after using "x2 save matching devices to"
I keep receiving a “Attention: the following door were left open for more than one minute empty device list” even if no door was left open
Only when a door sensor is open for more than 1 minute I would receive the warning
(UPLOAD YOUR IMAGE HERE)
Seeing an error with your log set to Full will help with troubleshooting
I’m certainly seeing some buggy behaviour with saving matching devices to a variable, when combined with stays.
On my test piston, it’s updating the variable with the device name immediately after light on (I’m using a light for testing), rather than waiting for the stays condition to come true.
But it is populating a log to the console correctly, triggered at the correct delay time, so I’m not sure why you are getting blank notifications.
Hi… Here is the detailed LOG:
8/14/2019, 8:40:56 PM +87ms
+1ms ╔Received event [Home].time = 1565826057571 with a delay of -1484ms
+128ms ║RunTime Analysis CS > 37ms > PS > 49ms > PE > 41ms > CE
+131ms ║Runtime (52391 bytes) successfully initialized in 49ms (v0.3.10e.20190628) (130ms)
+132ms ║╔Execution stage started
+137ms ║║Cancelling condition #18’s schedules…
+138ms ║║Condition #18 evaluated true (1ms)
+139ms ║║Cancelling condition #1’s schedules…
+140ms ║║Condition group #1 evaluated true (state changed) (4ms)
+142ms ║║Cancelling statement #3’s schedules…
+148ms ║║Calculating (string) Attention: the following door is open for more than one minute + (string) Empty device list >> (string) Attention: the following door is open for more than one minute Empty device list
+263ms ║║Executed physical command [Echo - Alexa].setVolumeSpeakAndRestore([50, Attention: the following door is open for more than one minute Empty device list]) (107ms)
+264ms ║║Executed [Echo - Alexa].setVolumeSpeakAndRestore (110ms)
+269ms ║║Calculating (string) Atenção: as seguintes portas estão abertas por mais de um minuto: + (string) Empty device list >> (string) Atenção: as seguintes portas estão abertas por mais de um minuto: Empty device list
+448ms ║║Executed virtual command [Echo - Alexa].sendPushNotification (176ms)
+453ms ║║Calculating (string) Atenção: as seguintes portas estão abertas por mais de um minuto: + (string) Empty device list >> (string) Atenção: as seguintes portas estão abertas por mais de um minuto: Empty device list
+529ms ║║Executed virtual command [Echo - Alexa].sendSMSNotification (71ms)
+539ms ║║Condition #19 evaluated false (7ms)
+540ms ║║Condition group #11 evaluated false (state did not change) (8ms)
+549ms ║║Condition #56 evaluated false (5ms)
+550ms ║║Condition group #55 evaluated false (state did not change) (8ms)
+552ms ║║Cancelling statement #59’s schedules…
+563ms ║║Executed virtual command sendSMSNotification (5ms)
+565ms ║╚Execution stage complete. (432ms)
+566ms ╚Event processed successfully (565ms)
8/14/2019, 8:40:02 PM +380ms
+1ms ╔Received event [Front Door Sensor].contact = closed with a delay of 95ms
+5390ms ║RunTime Analysis CS > 19ms > PS > 5291ms > PE > 81ms > CE
+5391ms ║Piston waited at a semaphore for 5259ms
+5394ms ║Runtime (52500 bytes) successfully initialized in 5291ms (v0.3.10e.20190628) (5391ms)
+5394ms ║╔Execution stage started
+5412ms ║║Comparison (enum) closed stays (string) open = false (1ms)
+5414ms ║║Comparison (enum) closed stays (string) open = false (2ms)
+5416ms ║║Comparison (enum) closed stays (string) open = false (1ms)
+5420ms ║║Cancelling any timed trigger schedules for device :f57ed50f589821d61d86ce5dcdbf88f2: for condition 18
+5421ms ║║Cancelling statement #18’s schedules…
+5422ms ║║Cancelling any timed trigger schedules for device :4e999c23f3dbb335a2457b573dd78128: for condition 18
+5423ms ║║Cancelling statement #18’s schedules…
+5423ms ║║Cancelling any timed trigger schedules for device :fd2df8c48844edb3c05c0effd20d6dc3: for condition 18
+5424ms ║║Cancelling statement #18’s schedules…
+5425ms ║║Condition #18 evaluated false (27ms)
+5426ms ║║Condition group #1 evaluated false (state did not change) (28ms)
+5431ms ║║Comparison (enum) closed changes_to (string) open = false (1ms)
+5432ms ║║Cancelling condition #19’s schedules…
+5433ms ║║Condition #19 evaluated false (5ms)
+5434ms ║║Cancelling condition #11’s schedules…
+5435ms ║║Condition group #11 evaluated false (state changed) (7ms)
+5443ms ║║Condition #56 evaluated false (6ms)
+5444ms ║║Condition group #55 evaluated false (state did not change) (7ms)
+5446ms ║║Cancelling statement #59’s schedules…
+5458ms ║║Executed virtual command sendSMSNotification (7ms)
+5460ms ║╚Execution stage complete. (65ms)
+5461ms ╚Event processed successfully (5461ms)
8/14/2019, 8:39:57 PM +415ms
+1ms ╔Received event [Front Door Sensor].contact = open with a delay of 92ms
+123ms ║RunTime Analysis CS > 18ms > PS > 35ms > PE > 70ms > CE
+126ms ║Runtime (52396 bytes) successfully initialized in 35ms (v0.3.10e.20190628) (124ms)
+127ms ║╔Execution stage started
+146ms ║║Comparison (enum) open stays (string) open = true (2ms)
+148ms ║║Comparison (enum) closed stays (string) open = false (1ms)
+151ms ║║Comparison (enum) closed stays (string) open = false (1ms)
+156ms ║║Adding a timed trigger schedule for device :f57ed50f589821d61d86ce5dcdbf88f2: for condition 18
+158ms ║║Cancelling any timed trigger schedules for device :4e999c23f3dbb335a2457b573dd78128: for condition 18
+159ms ║║Cancelling statement #18’s schedules…
+160ms ║║Cancelling any timed trigger schedules for device :fd2df8c48844edb3c05c0effd20d6dc3: for condition 18
+160ms ║║Cancelling statement #18’s schedules…
+161ms ║║Condition #18 evaluated false (29ms)
+162ms ║║Condition group #1 evaluated false (state did not change) (31ms)
+168ms ║║Comparison (enum) open changes_to (string) open = true (0ms)
+169ms ║║Cancelling condition #19’s schedules…
+170ms ║║Condition #19 evaluated true (5ms)
+171ms ║║Cancelling condition #11’s schedules…
+172ms ║║Condition group #11 evaluated true (state changed) (8ms)
+177ms ║║Comparison (string) Eduardo is (string) Cyntia = false (1ms)
+179ms ║║Condition #21 evaluated false (4ms)
+180ms ║║Condition group #20 evaluated false (state did not change) (5ms)
+186ms ║║Comparison (string) Eduardo is (string) Eduardo = true (1ms)
+187ms ║║Cancelling condition #30’s schedules…
+188ms ║║Condition #30 evaluated true (6ms)
+192ms ║║Comparison (boolean) true is (boolean) true = true (1ms)
+193ms ║║Condition #31 evaluated true (4ms)
+195ms ║║Cancelling condition #29’s schedules…
+195ms ║║Condition group #29 evaluated true (state changed) (13ms)
+211ms ║║Comparison (time) 74397613 is_between (time) 64800000 … (time) 21600000 = true (8ms)
+212ms ║║Time restriction check passed
+214ms ║║Condition #48 evaluated true (15ms)
+215ms ║║Condition group #47 evaluated true (state did not change) (17ms)
+217ms ║║Cancelling statement #49’s schedules…
+683ms ║║Executed physical command [Tv Light].on() (461ms)
+684ms ║║Executed [Tv Light].on (464ms)
+698ms ║║Executed virtual command [Tv Light].sendSMSNotification (9ms)
+708ms ║║Executed virtual command [Tv Light].sendSMSNotification (5ms)
+712ms ║║Cancelling statement #52’s schedules…
+715ms ║║Executed virtual command wait (0ms)
+715ms ║║Waiting for 3000ms
+3718ms ║║Cancelling statement #32’s schedules…
+4390ms ║║Executed physical command [Echo - Alexa].setVolumeAndSpeak([50, Hi Eduardo!]) (663ms)
+4391ms ║║Executed [Echo - Alexa].setVolumeAndSpeak (665ms)
+4394ms ║║Executed virtual command [Echo - Alexa].wait (1ms)
+4395ms ║║Waiting for 1000ms
+5423ms ║║Executed physical command [Echo - Alexa].sayWelcomeHome() (25ms)
+5424ms ║║Executed [Echo - Alexa].sayWelcomeHome (27ms)
+5428ms ║║Executed virtual command [Echo - Alexa].wait (1ms)
+5429ms ║║Waiting for 1000ms
+6462ms ║║Executed physical command [Echo - Alexa].sayCompliment() (31ms)
+6463ms ║║Executed [Echo - Alexa].sayCompliment (33ms)
+6468ms ║║Executed virtual command [Echo - Alexa].setVariable (1ms)
+6472ms ║║Executed virtual command [Echo - Alexa].setVariable (1ms)
+6481ms ║║Condition #56 evaluated false (6ms)
+6482ms ║║Condition group #55 evaluated false (state did not change) (7ms)
+6484ms ║║Cancelling statement #59’s schedules…
+6494ms ║║Executed virtual command sendSMSNotification (4ms)
+6496ms ║╚Execution stage complete. (6368ms)
+6497ms ║Setting up scheduled job for Wed, Aug 14 2019 @ 8:40:57 PM BRT (in 53.66s)
+6505ms ╚Event processed successfully (6505ms)
I can’t figure out why the notification is firing despite the door having been closed beforehand… the device list is empty because doors are closed, so shouldn’t fire??
Perhaps dumb it down a bit, break into separate pistons per door.
I use the following piston for a back gate, it sends me a message every 10 minutes reminding me the gate is open, with dynamic text stating the duration the gate has been open:
WARNING - The back gate has been open for 10 minutes
WARNING - The back gate has been open for 20 minutes
WARNING - The back gate has been open for 1 hour and 10 minutes
etc. etc.
