I am trying to make a piston that enforces the state of the light switches. For example if the light is on and then someone switches it off, the piston will turn the light back on. Now I have some lights set to off and some set to on. Also the lights are following a routine so they keep switching, therefore I set the piston to only toggle the switch if there’s physical interaction.
Keep the lights that are supposed to be on, on and if they’re supposed to be off, then off.
It keeps toggling on and off
Not letting me put the log in because it has more than 2 links and I’m a new user
