Error with local http request handler, throwing an error java.lang.NullPointerException and not executing at all. I have tried different ways of formatting the URL, tried both with and without the authorization headers, I always get the same error. Unlike in a thread with a similar error message, in this case the BOND home returns a Content-Type with its return. On a successful execution using:
curl -H “BOND-TOKEN: aaabbbccc111” -i http://1.1.1.1/v2/devices/aaaaaaaa/commands/ggggggg/tx
I get back:
HTTP/1.1 200 OK
Content-Length: 18
Content-Type: application/json; charset=utf-8
{"_":“111b2222”}
I am beta testing the BOND home API. I use several other Pistons with the “Make a web request” feature, but this one is causing trouble for some reason. What I want to have happen is an http get request to be issued to the appropriate URL and cause the BOND to transmit the correct RF single to my ceiling fan
I get an error in the trace log and it looks like no http request is made. The BOND never activates.
Here is a screen shot of the piston. I changed the IP address, auth token, device ID, and command ID for security reasons
8:30:50 PM: error java.lang.NullPointerException: Cannot invoke method tokenize() on null object @line 3167 (localHttpRequestHandler)
8:30:49 PM: info ╔ Event processed successfully (164ms)
8:30:49 PM: trace ║║ Requesting a wake up for Mon, May 6 2019 @ 8:31:09 PM CDT (in 20.0s)
8:30:49 PM: debug ║║ Cancelling statement #3’s schedules…
8:30:49 PM: debug ║║ Cancelling condition #1’s schedules…
8:30:49 PM: debug ║║ Cancelling condition #2’s schedules…
8:30:49 PM: debug ║║ Comparison (enum) pushed gets (string) pushed = true (1ms)
8:30:49 PM: trace ║╚ Execution stage started
8:30:49 PM: trace ║ Runtime (37622 bytes) successfully initialized in 55ms (v0.3.109.20181207) (108ms)
8:30:49 PM: debug ║ RunTime Analysis CS > 25ms > PS > 55ms > PE > 29ms > CE
8:30:49 PM: info ╚ Received event [Wyatt Bedroom Switch].button = pushed with a delay of 888ms
