Corner Lamp not turning off after WAIT
- Motion sensor turns on corner lamp
- 60 seconds elapse
- Corner lamp turns off
- Works correctly
- Logs show 60 seconds elapsing
- Corner lamp stays on, log shows no command sent to turn it off
(PASTE YOUR LOGS HERE BETWEEN THE MARKS THEN HIGHLIGHT ALL OF THE LOGS SND CLICK ON THE < 2/20/2019, 8:07:11 AM +125ms
| +0ms | âReceived event [Myhub].time = 1550668032010 with a delay of -886ms |
| +165ms | âRunTime Analysis CS > 20ms > PS > 129ms > PE > 17ms > CE |
| +168ms | âRuntime (39606 bytes) successfully initialized in 129ms (v0.3.109.20181207) (167ms) |
| +169ms | ââExecution stage started |
| +171ms | ââExecution stage complete. (1ms) |
| +172ms | âEvent processed successfully (172ms) |
| 2/20/2019, 8:06:15 AM +602ms | |
| +1ms | âReceived event [F-Motion Sensor].motion = inactive with a delay of 972ms |
| +125ms | âRunTime Analysis CS > 15ms > PS > 97ms > PE > 13ms > CE |
| +127ms | âRuntime (39605 bytes) successfully initialized in 97ms (v0.3.109.20181207) (125ms) |
| +129ms | ââExecution stage started |
| +139ms | ââComparison (enum) inactive changes_to (string) active = false (1ms) |
| +141ms | ââCancelling condition #2âs schedules⌠|
| +143ms | ââCondition #2 evaluated false (7ms) |
| +144ms | ââCancelling condition #1âs schedules⌠|
| +145ms | ââCondition group #1 evaluated false (state changed) (10ms) |
| +148ms | ââExecution stage complete. (20ms) |
| +150ms | âEvent processed successfully (149ms) |
| 2/20/2019, 8:06:11 AM +558ms | |
| +2ms | âReceived event [F-Motion Sensor].motion = active with a delay of 1010ms |
| +303ms | âRunTime Analysis CS > 28ms > PS > 259ms > PE > 15ms > CE |
| +305ms | âRuntime (39613 bytes) successfully initialized in 259ms (v0.3.109.20181207) (302ms) |
| +306ms | ââExecution stage started |
| +317ms | ââComparison (enum) active changes_to (string) active = true (1ms) |
| +319ms | ââCancelling condition #2âs schedules⌠|
| +320ms | ââCondition #2 evaluated true (8ms) |
| +322ms | ââCancelling condition #1âs schedules⌠|
| +323ms | ââCondition group #1 evaluated true (state changed) (11ms) |
| +326ms | ââCancelling statement #3âs schedules⌠|
| +443ms | ââExecuted physical command [Corner Lamp].on() (113ms) |
| +444ms | ââExecuted [Corner Lamp].on (115ms) |
| +449ms | ââExecuted virtual command [Corner Lamp].wait (1ms) |
| +451ms | ââRequesting a wake up for Wed, Feb 20 2019 @ 8:07:12 AM EST (in 60.0s) |
| +457ms | ââExecution stage complete. (150ms) |
| +459ms | âSetting up scheduled job for Wed, Feb 20 2019 @ 8:07:12 AM EST (in 59.994s) |
| +469ms | âEvent processed successfully (468ms) |
