I’m trying to setup a routine to turn the heating to away when everyone is out OR to run the normal schedule when someone is at home.
When presence of all our mobile phone are detected as away the heating is set to away mode- so cooler. When someone returns it go back to run the regular heating schedule.
When someone leaves the thermostat is turned down to away mode OK. When someone arrives setting the mode to schedule or heat is not working.
