Just thought I’d share a simple thermostat scheduling piston. It’s for 3 thermostats, each with different set points. The switch at the top that determines when it runs is a virtual “schedule hold” switch. If it is on then the schedule won’t run. If it is off then it will run. I have separate momentary buttons that I would push if I wanted it in vacation mode or home mode (as in during the week and I am off work).
Example Multi-thermostat Auto Schedule
kes601
I had to re-work this and split up the heating and cooling set points as setting them at the same time caused the heating set points to get adjusted down 3 degrees below the cooling set point.
