I’m calling a piston (P2) from within another piston (P1). The trouble I have is that after calling P2, it returns immediately to P1 even though it takes between 2.5 min and 13 min to finish. I have the setting for the Execute to Wait for Finish set to True but that is not working. It always returns immediately regardless of that setting. Is there something else I need to do to make that work as I intend? Are there commands in P2 that could be short-circuiting the process of waiting for the whole piston to be completed?
Also, is there a place that describes using Args when calling pistons from other pistons? I would like to pass a value to P2 from P1 and have P2 immediately use it.
Update: I figured out the $arg question.
