First I want to say how glad I am to have found webCoRE (and a lot of the users I’ve already learned so much from).
The expression I’m using to compare $locationMode to the ST Modes (defined in text) is coming up differently than what is shown on the webCoRE portal home screen
By running the expression, I am hoping to have it figure out which is the current mode and assign a variable that I’ve defined to things like light levels and timers further down the script.
Right now it’s executing ‘true’ for the first item in the string, which is not correct. When I run a new expression statement using just the $locationMode, it reads properly. Its causing the timeouts and intensity levels to be incorrect.
