"Fade to" vs "Set level"
When I started setting up pistons, I plucked for the “Fade to” action a lot, and found the results to be variable based on the kind of light I was controlling. For Hue lights, they seem to rapidly cycle through bright, very dim, brighter, and then bright again, while a Qubino dimmer unit turns on bright and then dims, or the other way around, unpredictably.
I then discovered “Set level” which seems more reliable but doesn’t seem to do much in the way of smooth dimming - the lights change level pretty instantly.
I also noticed that with “Fade level” the logs show webcore sending multiple commands to the lights over a short period with different levels. This seems like a bit of a hack, for lights that don’t accept 'fade to x over y seconds" type commands? And my lights seem to receive those commands out of order, maybe.
So I guess my questions are:
  • Is there a recommended set of devices that work well with “fade to” (especially in-wall dimmers)?
  • Do people generally use this command or is ‘set level’ more common?
  • Any other tips on getting lots of dimmers across the house to dim in sync?
It’s trial and error for now… the longer the fade duration the smoother the transition will be.
I can’t think of any devices that can receive fade to x in y seconds commands directly, the hack of sending multiple commands is the best workaround we have.
WebCoRE tries to make as many steps as possible, dividing % difference by time, but limits this to 1 command every 3 seconds, so very short fade durations result in large steps which can look jerky.
