I have an Aeotec Multisensor that controls a bathroom fan (the fan is switched by an Aeotec Nano Switch)
The issue is that the ambient humidty appears to be high in that room, therefore I’d like to compare the humidity from another room and if there difference is by X amount, then activate the fan.
This is my first piston and can’t quite workout how to logically look at the difference.
I’d like to create a piston that compares the humidity of Aeotec Multisensor and the Netatmo home weather station (base station) and if there is a difference of 10% activate a a fan controlled by an Aeotec Nano Switch.
(PUT YOUR INFO HERE)
(UPLOAD YOUR IMAGE HERE)
