Random results.
Very simple piston. Turn the ceiling fan on when the ecobee heat turns on
If manually raise the temp on the thermostat it seems to work. If the schedule kicks on because its too cool it doesn’t work all the time. I did catch it once and quickly opened webcore and clicked trace and shortly after it turned back on. Is there a better way I can do this?
|+1ms|╔Received event [Ecobee Downstairs].thermostatOperatingState = heating with a delay of 51ms|
|+71ms|║RunTime Analysis CS > 17ms > PS > 45ms > PE > 9ms > CE|
|+73ms|║Runtime (37023 bytes) successfully initialized in 45ms (v0.3.109.20181207) (71ms)|
|+74ms|║╔Execution stage started|
|+86ms|║║Comparison (enum) heating is (string) heating = true (2ms)|
|+87ms|║║Cancelling condition #2’s schedules…|
|+89ms|║║Condition #2 evaluated true (8ms)|
|+90ms|║║Cancelling condition #1’s schedules…|
|+91ms|║║Condition group #1 evaluated true (state changed) (11ms)|
|+94ms|║║Cancelling statement #4’s schedules…|
|+582ms|║║Executed physical command [Family Room Fan].setLevel([80]) (482ms)|
|+583ms|║║Executed [Family Room Fan].setLevel (483ms)|
|+586ms|║╚Execution stage complete. (512ms)|
|+588ms|╚Event processed successfully (587ms)|
