sorry new to this , so not sure if this is the right place to do this .
I want to turn my fan on with a motion sensor and have it run for a set time.
any help is appreciated .
Fan on with motion and off with timer
Ryanb907
ike2018
you can start with this:
IF motion sensor status CHANGES TO ACTIVE
then
With Fan
Do Turn ON
IF motion sensor status STAYS INACTIVE for X minutes
then
with fan
Do turn OFF
WCmore
If you want the fan to stay on a precise amount of time, (regardless if the room is occupied or not), then here is a slight variation:
With Fan (TCP set to Never)
Turn ON
WAIT X minutes
Turn OFF
END IF
With Task Cancellation Policy set to never, it will continue with the code⦠Even if the motion sensor changes again.
