Hi im really struggling here have googled this and searched this forum but for days i just cant get this right all i want to do is assign actions to buttons on the key fob as i have in the image but ive done it so many different ways and i cant work it out im a total newbie at webcore or anything like it any help here would be very much appreciated
Thnx
Fibaro Key Fob HELP!
TroyBootsa
ike2018
Hi there…
couple of things really fast,
1 - You second condition LINE #20 is same as line 18 (Same button, same key)
delete line 20
2 - IF block without anything - Line 25
3 - IF block within IF blocks (won’t work that way)
4 - You are trying to OPEN and CLOSE “Contact Sensors” ??? I believe you are trying to achieve something else…
The best way to start would be, tell us what it is that you want to happen in the house, me or some else can get you started…
ike2018
Pls share the solution and mark it as solved. That would help people coming later on and reading this.
