While this isn’t specifically a WC issue, I do need help figuring out what HSL values to set in a piston…
If I set a color in the ST app, and then look at the events for the bulb in IDE, I see logs for it setting hue and saturation (but no level). If I use WC to set those hue and saturation levels, and guess on level based on some web based color calculators, the result is not even close.
So any ideas on how to find correct HSL values to put in for a bulb?
