I enabled a filter (“only when”) and it is not working as I expected it to
I have a global variable and I only want to evaluate the if statement when the global variable has a particular value
The global variable has the particular value but the event trigger is not being seen by the if statement. The piston is not running at all when the motion happens
I checked logs for one of the motion sensors and there was motion and its lux level was less than the global LuxValue.
