The first piston is a fireplace. It will pull up a 10 hour loop on YouTube and display it on an Android TV or device running fully browser
The second piston tracks Santa with the Google santa tracker.
Since the anonymous piston shows my password I had to remove piston code and url. Substitute for your own.
Make sure you turn on remote in Fully and change the IP in this piston for your own. I also created two virtual momentary buttons and add them to a ST routine
to trigger from my phone
I sideloaded fully (using join) on my Nvidia shield and used a mouse to setup).
