I am looking to create a piston that only allows the fireplace to be turned on if I or my wife are at home (keep the college kid from burning up my gas bill) using a MIMOLite controller. The attached is not complete as I know what the outcome will be: If using the switch on event of the piston will re-trigger the piston to cause a switch off event.
If my wife or I am home, and either the switch is flipped or home automation is used to turn on the fireplace, it will turn on. Otherwise, nothing happens
The fireplace keeps cycling on and off
image|45x37
