I am new to WebCore. I am trying to write my first Piston and have encountered 2 issues. I have researched the errors and cant figure out what is causing this. I orginally wrote this as every October 1st, but result was the same.
On October 1st of every year I want to turn on a virtual switch
I am getting 2 errors, 1) I am getting This piston does not subscribe to any events. Unless executed by other means, it will never run on its own. and 2) I am seeing a null pointer error every time I run.
` 10/16/2019, 2:21:10 PM +192ms
+1ms ╔Received event [Vail].test = 1571257270189 with a delay of 3ms
+64ms ║RunTime Analysis CS > 18ms > PS > 32ms > PE > 14ms > CE
+67ms ║Runtime (36597 bytes) successfully initialized in 32ms (v0.3.110.20191009) (64ms)
+102ms ║║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method toInteger() on null object
+105ms ║╚Execution stage complete. (38ms)
+106ms ╚Event processed successfully (106ms)
