I am trying to make a piston to control some lamps with the push of a button. I was trying to change the temperature of the light with each push. I think the problem is the variable I have made, I’m not sure that I use the variable right.
The lamps should change temperature with each push of the button. Until I push button 2, that turn off the light.
The lamps turns on when I press the button, but I cant control the temperature. They start at one temperature, but changes by them self.
### Logs
10/9/2019, 11:42:07 PM +90ms
+0ms ╔Received event [IKEA On/Off switch 1 top button].button = pushed with a delay of 33ms
+60ms ║RunTime Analysis CS > 13ms > PS > 31ms > PE > 16ms > CE
+62ms ║Runtime (41567 bytes) successfully initialized in 31ms (v0.3.10f.20190822) (61ms)
+63ms ║╔Execution stage started
+72ms ║║Comparison (enum) pushed gets (string) pushed = true (1ms)
+74ms ║║Cancelling condition #2's schedules...
+75ms ║║Condition #2 evaluated true (6ms)
+76ms ║║Cancelling condition #1's schedules...
+77ms ║║Condition group #1 evaluated true (state changed) (9ms)
+83ms ║║Comparison (integer) 0 is_equal_to (integer) 0 = true (2ms)
+85ms ║║Condition #15 evaluated true (6ms)
+86ms ║║Condition group #13 evaluated true (state did not change) (7ms)
+89ms ║║Cancelling statement #16's schedules...
+95ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+101ms ║║Executed virtual command [Spisebord light 1, Spisebord light 2, Spisebord light 3].setVariable (2ms)
+116ms ║║Executed physical command [Spisebord light 1].setColorTemperature([2200]) (12ms)
+118ms ║║Executed [Spisebord light 1].setColorTemperature (13ms)
+132ms ║║Executed physical command [Spisebord light 2].setColorTemperature([2200]) (10ms)
+133ms ║║Executed [Spisebord light 2].setColorTemperature (13ms)
+146ms ║║Executed physical command [Spisebord light 3].setColorTemperature([2200]) (9ms)
+147ms ║║Executed [Spisebord light 3].setColorTemperature (12ms)
+154ms ║║Comparison (integer) 1 is_equal_to (integer) 1 = true (2ms)
+156ms ║║Condition #49 evaluated true (5ms)
+157ms ║║Condition group #48 evaluated true (state did not change) (7ms)
+160ms ║║Cancelling statement #50's schedules...
+166ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+171ms ║║Executed virtual command [Spisebord light 1, Spisebord light 2, Spisebord light 3].setVariable (3ms)
+184ms ║║Executed physical command [Spisebord light 1].setColorTemperature([2700]) (9ms)
+185ms ║║Executed [Spisebord light 1].setColorTemperature (11ms)
+196ms ║║Executed physical command [Spisebord light 2].setColorTemperature([2700]) (8ms)
+197ms ║║Executed [Spisebord light 2].setColorTemperature (10ms)
+234ms ║║Executed physical command [Spisebord light 3].setColorTemperature([2700]) (36ms)
+235ms ║║Executed [Spisebord light 3].setColorTemperature (38ms)
+242ms ║║Comparison (integer) 2 is_equal_to (integer) 2 = true (2ms)
+244ms ║║Condition #58 evaluated true (5ms)
+245ms ║║Condition group #57 evaluated true (state did not change) (7ms)
+247ms ║║Cancelling statement #59's schedules...
+253ms ║║Executed virtual command [Spisebord light 1, Spisebord light 2, Spisebord light 3].setVariable (2ms)
+265ms ║║Executed physical command [Spisebord light 1].setColorTemperature([4000]) (9ms)
+266ms ║║Executed [Spisebord light 1].setColorTemperature (10ms)
+276ms ║║Executed physical command [Spisebord light 2].setColorTemperature([4000]) (9ms)
+277ms ║║Executed [Spisebord light 2].setColorTemperature (10ms)
+287ms ║║Executed physical command [Spisebord light 3].setColorTemperature([4000]) (8ms)
+288ms ║║Executed [Spisebord light 3].setColorTemperature (9ms)
+297ms ║║Cancelling condition #7's schedules...
+298ms ║║Condition #7 evaluated false (6ms)
+299ms ║║Cancelling condition #6's schedules...
+300ms ║║Condition group #6 evaluated false (state changed) (8ms)
+302ms ║╚Execution stage complete. (239ms)
+303ms ╚Event processed successfully (303ms)
