I’m wondering why this piston does not fire. I expect it to fire. The button is pressed, and there is motion in the sensor within 25 seconds. The logging shows that there is both, because it logs both the button press and the motion. Both are triggers, so that should work, right?
Keypad 3 = a button, only 1 button (the only button is selected, and I tried not selecting any button number, and nothing)
Motion sensor is a motion sensor that is correctly reporting as motion active.
Switch is a power socker that turns on a bedside lamp.
Turn on light switch.
Light is not turned on. It’s either the “followed by” is not working, or I’ve selected the wrong matching method.
5) Attach any logs and by turning logging level to Full)
17/09/2018, 20:36:47 +90ms
+0ms ╔Received event [EU Location].time = 1537180607612 with a delay of -523ms
+160ms ║RunTime Analysis CS > 44ms > PS > 63ms > PE > 53ms > CE
+163ms ║Runtime (37813 bytes) successfully initialized in 63ms (v0.3.108.20180906) (161ms)
+164ms ║╔Execution stage started
+177ms ║╚Execution stage complete. (14ms)
+179ms ╚Event processed successfully (178ms)
17/09/2018, 20:36:31 +288ms
+1ms ╔Received event [MD - Main Bed].motion = active with a delay of 84ms
+115ms ║RunTime Analysis CS > 16ms > PS > 50ms > PE > 49ms > CE
+117ms ║Runtime (37808 bytes) successfully initialized in 50ms (v0.3.108.20180906) (115ms)
+131ms ║║Comparison (enum) active changes_to (string) active = false (0ms)
+132ms ║║Condition #3 evaluated false (6ms)
+135ms ║╚Execution stage complete. (17ms)
+137ms ║Setting up scheduled job for Mon, Sep 17 2018 @ 8:36:47 PM AEST (in 16.188s)
+148ms ╚Event processed successfully (148ms)
17/09/2018, 20:36:22 +454ms
+2ms ╔Received event [Button 4 - Mike Comp].button = pushed with a delay of 179ms
+128ms ║RunTime Analysis CS > 22ms > PS > 52ms > PE > 53ms > CE
+130ms ║Runtime (37805 bytes) successfully initialized in 52ms (v0.3.108.20180906) (127ms)
+144ms ║║Comparison (enum) pushed gets (string) pushed = true (3ms)
+146ms ║║Cancelling condition #2’s schedules…
+147ms ║║Condition #2 evaluated true (10ms)
+148ms ║║Cancelling statement #1’s schedules…
+151ms ║║Condition group #1 made progress up the ladder, currently at step 1 of 2
+163ms ║╚Execution stage complete. (31ms)
+165ms ║Setting up scheduled job for Mon, Sep 17 2018 @ 8:36:47 PM AEST (in 24.994s)
+174ms ╚Event processed successfully (174ms)
17/09/2018, 20:36:15 +734ms
+1ms ╔Received event [EU Location].test = 1537180575733 with a delay of 1ms
+148ms ║RunTime Analysis CS > 24ms > PS > 56ms > PE > 68ms > CE
+152ms ║Runtime (37797 bytes) successfully initialized in 56ms (v0.3.108.20180906) (149ms)
+153ms ║╔Execution stage started
+170ms ║║Cancelling condition #2’s schedules…
+171ms ║║Condition #2 evaluated false (10ms)
+173ms ║║Cancelling statement #1’s schedules…
+175ms ║║Cancelling condition #1’s schedules…
+176ms ║║Condition group #1 evaluated false (state changed) (17ms)
+183ms ║╚Execution stage complete. (31ms)
+185ms ╚Event processed successfully (185ms)
17/09/2018, 20:36:10 +245ms
+1ms ╔Starting piston… (v0.3.108.20180906)
+468ms ║╔Subscribing to devices…
+503ms ║║Subscribing to Button 4 - Mike Comp.button…
+520ms ║║Subscribing to MD - Main Bed.motion…
+666ms ║║Subscribing to PS - Mike’s Lamp…
+667ms ║╚Finished subscribing (211ms)
+692ms ║Cancelling condition #1’s schedules…
+705ms ╚Piston successfully started (704ms)
