These example piston tiles make use of layers and feature background and foreground colors, rotating and/or flashing elements and counters:
Meant more as samples, you’ll need to hit test to see the tiles as there is no other triggering. The watts and amps counters are fed by variables so can be used with devices that offer those values.
