I have a piston that turns on my front entry light when the Ring doorbell gets pushed. After 10 minutes the front entry light should turn off. It turns on correctly but doesn’t turn off after 10 minutes as expected.
The front entry light should turn off after 10 minutes when it gets turned on via this piston.
The light turns on successfully when the Ring doorbell button is pushed, but it never turns off.
