Thanks for the info, I did verify the restriction by writing to a fuel stream using another smartapp in smartthings and had the result come through. Since the requests would originate from where each Hubitat hub is located, I’m not sure it’s feasible to disable that from his side.
@ady624 would you object to hubitat users writing to a fuel stream using a proxy smartthings app?
**Now that I think about it, it wouldn’t be too hard to create another webcore child app in Hubitat strictly for fuel streams since there isn’t a 100K limit on state, and just route it to that instead. It would require users though to use a custom local dashboard. If possible I’d like to keep them on dashboard.webcore.co since it’s globally accessible and the ad revenue can go to you, but I’m not sure if the added server costs for fuel streams would outweigh that.
