Hi
I have create a piston with this piston i want to open my garage door when me or my wife come to home and also if garage door open and is afternoon or night an other switch that is light will be turn on for 90sec this with light i want to happen also if open garage door by ST app even if i am inside to the home and open the garage door from the app
working when i am arrive to home the garage door open but the light does not turn on or if i open the garage door via app again the lights does not turn on
my 2nd try without succsess
New problem at post #13
When arrive together me and my wife at the same time with my presence start open garage door and a second after with my wife presence change so the door stop in the middle
So can make a rule if a 2nd person arrived in Window 2min do not run piston 2nd time?
