I double checked, and my sensor is indeed set to Garage-Door-Mode, so I was also expecting a single command to the hub, but my logs really show a flurry of activity and many commands back to back to back each time the door is opened or closed.
7/16/2020, 5:54:35 PM +646ms
+1ms ╔Received event [Garage Double Door].threeAxis = 44,31,-1035 with a delay of 53ms
+68ms ║RunTime Analysis CS > 17ms > PS > 4ms > PE > 47ms > CE
+70ms ║Runtime (38595 bytes) successfully initialized in 4ms (v0.3.110.20191009) (68ms)
+71ms ║╔Execution stage started
+78ms ║║Comparison (enum) right side up changes_to (string) rear side up = false (0ms)
+80ms ║║Condition #13 evaluated false (4ms)
+81ms ║║Condition group #12 evaluated false (state did not change) (5ms)
+83ms ║╚Execution stage complete. (11ms)
+84ms ║Setting up scheduled job for Thu, Jul 16 2020 @ 6:21:22 PM CDT (in 1606.867s)
+94ms ╚Event processed successfully (94ms)
7/16/2020, 5:54:34 PM +633ms
+1ms ╔Received event [Garage Double Door].threeAxis = 45,36,-1034 with a delay of 58ms
+67ms ║RunTime Analysis CS > 17ms > PS > 4ms > PE > 45ms > CE
+69ms ║Runtime (38595 bytes) successfully initialized in 4ms (v0.3.110.20191009) (68ms)
+70ms ║╔Execution stage started
+77ms ║║Comparison (enum) right side up changes_to (string) rear side up = false (0ms)
+79ms ║║Condition #13 evaluated false (5ms)
+80ms ║║Condition group #12 evaluated false (state did not change) (6ms)
+82ms ║╚Execution stage complete. (12ms)
+83ms ║Setting up scheduled job for Thu, Jul 16 2020 @ 6:21:22 PM CDT (in 1607.88s)
7/16/2020, 5:54:33 PM +695ms
+2ms ╔Received event [Garage Double Door].threeAxis = 38,34,-1032 with a delay of 122ms
+74ms ║RunTime Analysis CS > 18ms > PS > 5ms > PE > 51ms > CE
+76ms ║Runtime (38596 bytes) successfully initialized in 5ms (v0.3.110.20191009) (74ms)
+77ms ║╔Execution stage started
+85ms ║║Comparison (enum) right side up changes_to (string) rear side up = false (0ms)
+86ms ║║Condition #13 evaluated false (5ms)
+87ms ║║Condition group #12 evaluated false (state did not change) (6ms)
+89ms ║╚Execution stage complete. (12ms)
+91ms ║Setting up scheduled job for Thu, Jul 16 2020 @ 6:21:22 PM CDT (in 1608.811s)
+102ms ╚Event processed successfully (102ms)
7/16/2020, 5:54:32 PM +606ms
+2ms ╔Received event [Garage Double Door].threeAxis = 37,32,-1031 with a delay of 72ms
+75ms ║RunTime Analysis CS > 20ms > PS > 5ms > PE > 50ms > CE
+78ms ║Runtime (38595 bytes) successfully initialized in 5ms (v0.3.110.20191009) (76ms)
+86ms ║║Comparison (enum) right side up changes_to (string) rear side up = false (1ms)
+87ms ║║Condition #13 evaluated false (4ms)
+88ms ║║Condition group #12 evaluated false (state did not change) (6ms)
+90ms ║╚Execution stage complete. (12ms)
+92ms ║Setting up scheduled job for Thu, Jul 16 2020 @ 6:21:22 PM CDT (in 1609.899s)
+104ms ╚Event processed successfully (104ms)
7/16/2020, 5:54:31 PM +596ms
+2ms ╔Received event [Garage Double Door].threeAxis = -188,81,-1349 with a delay of 74ms
+80ms ║RunTime Analysis CS > 23ms > PS > 5ms > PE > 52ms > CE
+82ms ║Runtime (38597 bytes) successfully initialized in 5ms (v0.3.110.20191009) (79ms)
+90ms ║║Comparison (enum) right side up changes_to (string) rear side up = false (1ms)
+91ms ║║Condition #13 evaluated false (4ms)
+92ms ║║Condition group #12 evaluated false (state did not change) (6ms)
+94ms ║╚Execution stage complete. (11ms)
+95ms ║Setting up scheduled job for Thu, Jul 16 2020 @ 6:21:22 PM CDT (in 1610.905s)
+106ms ╚Event processed successfully (106ms)
7/16/2020, 5:54:30 PM +597ms
+2ms ╔Received event [Garage Double Door].threeAxis = 232,6,-1088 with a delay of 84ms
+85ms ║RunTime Analysis CS > 23ms > PS > 6ms > PE > 56ms > CE
+87ms ║Runtime (38595 bytes) successfully initialized in 6ms (v0.3.110.20191009) (84ms)
+96ms ║║Comparison (enum) right side up changes_to (string) rear side up = false (1ms)
+97ms ║║Condition #13 evaluated false (4ms)
+98ms ║║Condition group #12 evaluated false (state did not change) (6ms)
+101ms ║╚Execution stage complete. (12ms)
+102ms ║Setting up scheduled job for Thu, Jul 16 2020 @ 6:21:22 PM CDT (in 1611.898s)
+114ms ╚Event processed successfully (114ms)
7/16/2020, 5:54:29 PM +560ms
+1ms ╔Received event [Garage Double Door].threeAxis = 497,33,-846 with a delay of 64ms
+67ms ║RunTime Analysis CS > 17ms > PS > 4ms > PE > 46ms > CE
+70ms ║Runtime (38594 bytes) successfully initialized in 4ms (v0.3.110.20191009) (67ms)
+83ms ║Setting up scheduled job for Thu, Jul 16 2020 @ 6:21:22 PM CDT (in 1612.953s)
+93ms ╚Event processed successfully (93ms)
7/16/2020, 5:54:28 PM +534ms
+2ms ╔Received event [Garage Double Door].threeAxis = 1006,27,-357 with a delay of 80ms
+81ms ║RunTime Analysis CS > 25ms > PS > 6ms > PE > 50ms > CE
+83ms ║Runtime (38595 bytes) successfully initialized in 6ms (v0.3.110.20191009) (81ms)
+91ms ║║Comparison (enum) rear side up changes_to (string) rear side up = false (1ms)
+93ms ║║Condition #13 evaluated false (4ms)
+93ms ║║Condition group #12 evaluated false (state did not change) (5ms)
+96ms ║╚Execution stage complete. (11ms)
+97ms ║Setting up scheduled job for Thu, Jul 16 2020 @ 6:21:22 PM CDT (in 1613.966s)
+119ms ╚Event processed successfully (119ms)
7/16/2020, 5:54:27 PM +533ms
+0ms ╔Received event [Garage Double Door].threeAxis = 876,26,-74 with a delay of 61ms
+72ms ║RunTime Analysis CS > 18ms > PS > 3ms > PE > 52ms > CE
+74ms ║Runtime (38593 bytes) successfully initialized in 3ms (v0.3.110.20191009) (73ms)
+75ms ║╔Execution stage started
+83ms ║║Comparison (enum) rear side up changes_to (string) rear side up = false (1ms)
+84ms ║║Condition #13 evaluated false (4ms)
+85ms ║║Condition group #12 evaluated false (state did not change) (6ms)
+87ms ║╚Execution stage complete. (12ms)
+89ms ║Setting up scheduled job for Thu, Jul 16 2020 @ 6:21:22 PM CDT (in 1614.975s)
+101ms ╚Event processed successfully (101ms)
7/16/2020, 5:54:26 PM +550ms
+2ms ╔Received event [Garage Double Door].threeAxis = 1068,15,-159 with a delay of 126ms
+80ms ║RunTime Analysis CS > 23ms > PS > 6ms > PE > 50ms > CE
+82ms ║Runtime (38596 bytes) successfully initialized in 6ms (v0.3.110.20191009) (79ms)
+90ms ║║Comparison (enum) rear side up changes_to (string) rear side up = false (0ms)
+92ms ║║Condition #13 evaluated false (4ms)
+95ms ║╚Execution stage complete. (11ms)
+96ms ║Setting up scheduled job for Thu, Jul 16 2020 @ 6:21:22 PM CDT (in 1615.951s)
7/16/2020, 5:54:25 PM +539ms
+2ms ╔Received event [Garage Double Door].threeAxis = 978,21,4 with a delay of 78ms
+83ms ║RunTime Analysis CS > 24ms > PS > 6ms > PE > 53ms > CE
+86ms ║Runtime (38591 bytes) successfully initialized in 6ms (v0.3.110.20191009) (83ms)
+87ms ║╔Execution stage started
+94ms ║║Comparison (enum) rear side up changes_to (string) rear side up = false (0ms)
+95ms ║║Condition #13 evaluated false (4ms)
+96ms ║║Condition group #12 evaluated false (state did not change) (6ms)
+98ms ║╚Execution stage complete. (12ms)
+99ms ║Setting up scheduled job for Thu, Jul 16 2020 @ 6:21:22 PM CDT (in 1616.958s)
+112ms ╚Event processed successfully (111ms)
7/16/2020, 5:54:25 PM +64ms
+1ms ╔Received event [Garage Double Door].threeAxis = 1069,24,-102 with a delay of 76ms
+84ms ║RunTime Analysis CS > 24ms > PS > 6ms > PE > 54ms > CE
+86ms ║Runtime (38595 bytes) successfully initialized in 6ms (v0.3.110.20191009) (84ms)
+95ms ║║Comparison (enum) rear side up changes_to (string) rear side up = false (1ms)
+98ms ║║Condition group #12 evaluated false (state did not change) (5ms)
+100ms ║╚Execution stage complete. (13ms)
+101ms ║Setting up scheduled job for Thu, Jul 16 2020 @ 6:21:22 PM CDT (in 1617.431s)
+116ms ╚Event processed successfully (117ms)
7/16/2020, 5:54:23 PM +470ms
+1ms ╔Received event [Garage Double Door].threeAxis = 1129,41,-91 with a delay of 56ms
+65ms ║RunTime Analysis CS > 16ms > PS > 4ms > PE > 44ms > CE
+67ms ║Runtime (38594 bytes) successfully initialized in 4ms (v0.3.110.20191009) (66ms)
+75ms ║║Comparison (enum) rear side up changes_to (string) rear side up = false (1ms)
+76ms ║║Condition #13 evaluated false (4ms)
+77ms ║║Condition group #12 evaluated false (state did not change) (6ms)
+79ms ║╚Execution stage complete. (12ms)
+81ms ║Setting up scheduled job for Thu, Jul 16 2020 @ 6:21:22 PM CDT (in 1619.046s)
+92ms ╚Event processed successfully (92ms)
7/16/2020, 5:54:22 PM +458ms
+0ms ╔Received event [Garage Double Door].threeAxis = 1109,35,-24 with a delay of 55ms
+62ms ║RunTime Analysis CS > 14ms > PS > 5ms > PE > 44ms > CE
+64ms ║Runtime (38594 bytes) successfully initialized in 5ms (v0.3.110.20191009) (63ms)
+65ms ║╔Execution stage started
+72ms ║║Comparison (enum) rear side up changes_to (string) rear side up = false (1ms)
+73ms ║║Condition #13 evaluated false (4ms)
+74ms ║║Condition group #12 evaluated false (state did not change) (5ms)
+77ms ║╚Execution stage complete. (12ms)
+78ms ║Setting up scheduled job for Thu, Jul 16 2020 @ 6:21:22 PM CDT (in 1620.061s)
+161ms ╚Event processed successfully (160ms)
7/16/2020, 5:54:21 PM +444ms
+2ms ╔Received event [Garage Double Door].threeAxis = 1188,-1,-166 with a delay of 76ms
+74ms ║RunTime Analysis CS > 21ms > PS > 5ms > PE > 48ms > CE
+77ms ║Runtime (38595 bytes) successfully initialized in 5ms (v0.3.110.20191009) (74ms)
+84ms ║║Comparison (enum) rear side up changes_to (string) rear side up = false (0ms)
+86ms ║║Condition #13 evaluated false (4ms)
+87ms ║║Condition group #12 evaluated false (state did not change) (5ms)
+89ms ║╚Execution stage complete. (11ms)
+90ms ║Setting up scheduled job for Thu, Jul 16 2020 @ 6:21:22 PM CDT (in 1621.063s)
+103ms ╚Event processed successfully (103ms)
7/16/2020, 5:54:20 PM +497ms
+2ms ╔Received event [Garage Double Door].threeAxis = 1146,-49,34 with a delay of 69ms
+77ms ║RunTime Analysis CS > 20ms > PS > 5ms > PE > 51ms > CE
+79ms ║Runtime (38594 bytes) successfully initialized in 5ms (v0.3.110.20191009) (77ms)
+87ms ║║Comparison (enum) rear side up changes_to (string) rear side up = false (1ms)
+88ms ║║Condition #13 evaluated false (4ms)
+89ms ║║Condition group #12 evaluated false (state did not change) (6ms)
+91ms ║╚Execution stage complete. (12ms)
+93ms ║Setting up scheduled job for Thu, Jul 16 2020 @ 6:21:22 PM CDT (in 1622.007s)
7/16/2020, 5:54:19 PM +584ms
+2ms ╔Received event [Garage Double Door].threeAxis = 1212,8,-37 with a delay of 68ms
+71ms ║RunTime Analysis CS > 21ms > PS > 5ms > PE > 45ms > CE
+73ms ║Runtime (38593 bytes) successfully initialized in 5ms (v0.3.110.20191009) (71ms)
+81ms ║║Comparison (enum) rear side up changes_to (string) rear side up = false (0ms)
+82ms ║║Condition #13 evaluated false (4ms)
+83ms ║║Condition group #12 evaluated false (state did not change) (5ms)
+85ms ║╚Execution stage complete. (11ms)
+87ms ║Setting up scheduled job for Thu, Jul 16 2020 @ 6:21:22 PM CDT (in 1622.926s)
+98ms ╚Event processed successfully (98ms)Preformatted text
