No problem, but rather a logic check of the piston. I am venturing out to use device definitions and case switching.
When either of the two defined presence sensors arrive, based on who arrives, open the respective garage door(s).
I have not implemented this piston, but wanted to get a logic check from someone
10/25/2020, 8:22:22 AM +561ms
+1ms ╔Received event [Home].test = 1603632142561 with a delay of 0ms
+53ms ║RunTime Analysis CS > 22ms > PS > 7ms > PE > 23ms > CE
+55ms ║Runtime (43291 bytes) successfully initialized in 7ms (v0.3.110.20191009) (53ms)
+57ms ║╔Execution stage started
+84ms ║║Condition #2 evaluated false (22ms)
+85ms ║║Condition group #1 evaluated false (state did not change) (24ms)
+89ms ║╚Execution stage complete. (33ms)
+90ms ╚Event processed successfully (90ms)
