Hi Egoman,
I’m a newbie just getting started using webCoRE and its powerful capabilities to extend the uses of my Smartthings devices. While I don’t have an answer to your webCoRE question I have an alternate solution.
I’m also using a Smartthing’s contact sensor mounted on my garage door to provide door status and to push notifications to my phone. However, instead of using the acceleration I’m using the device status of (Open/Closed). Since I implemented my solution long before I discovered webCoRE I found a solution using Smartthings Smart Apps.
Here are the basic instructions on my implementation to push a notification using the garage door sensor status :
>>> Push Notification When Garage Door Opens <<<
Start Smartthings App > Marketplace > SmartApps > Safety & Security > Notify Me When
Contact Opens > Insert Your Garage Sensor Here
Notify me via Push Notification > Yes
Assign a name > Enter Message Here
Save
>>> Push Notification When Garage Door Closes <<<
Contact Closes > Insert Your Garage Sensor Here
Save
I’ve also created a number of push notifications if the garage door is open more than x minutes
>>> Push Notification When Garage Door Open More Than X Minutes <<<
Start Smartthings App > Marketplace > SmartApps > Safety & Security > Smart Home Monitor - Security > Custom > New Monitoring Rule > What kind of device do you want to use? > Open/Close Sensor >
Select Open/Close Sensors > Insert Your Garage Sensor Here
What Do You Want To Monitor?
Sensor Opens > Select Your Slider Here
For how long? (Mintues) > Enter your time here
Select Next
Text & Push Notification > Send push notification > Select Slider Here
Custom message > Enter Your Message Here
Save
Hope this helps.
Since I’m wanting to learn webCoRE if you find a solution to your question I’d appreciate a heads up
-Cheers
