Building a piston based on garage door sensors to control multiple ecobee lite thermostats. If any door sensors are open adjust the thermostats set point to a lower temp so the heat shuts off.
If any of the 12 mulit purpose sensors reads open change thermostat to away (away is a lower set point so the heat doesn’t run while doors are open. )
I can’t figure out how to adjust the thermostat to away mode. I’m using ecobee link in ST.
N/A
