when trying to pull information from the device for open time, close time, open message time and close message time i am getting an error in webcore. it really doesn’t make sense to me. the information is there in the device via the IDE. but when webcore tries to gather it and set it to a variable it errors out. all others seem to be fine. i am using the device as a contact.
populate the variable with set variable command
getting error reading attributes
device attributes in IDE:
logs from piston:
logs from IDE:
