I’m attempting to have a motion activated light at low brightness after a certain time. Once the motion trigger de-activates, I want the switch behavior to be at 100% light value (or 99% in GE’s case).
If light switch is turned on during the motion activation, I want the lights to go to full brightness. If the light switch is turned off, it should turn the dimmed / motion activated lights off (and subsequently be full brightness when turned back on, manually).
Motion activates the lights to 1% (tested, it is the brightness we want for this situation) between set times. Light stays on for 10 min and then turns off.
ON switch press will activate lights to 99/100% during the motion event (and cancel the 10 min timer) or during all other times.
OFF switch press will turn lights off under all conditions
-Motion is working and turning lights on properly
-On switch turns lights to full value
-Off Switch turns lights off and then they IMMEDIATELY turn back on to full value. I can’t turn my lights off
Appreciate any insite you guys can throw my way. I’m new to webcore and still trying to figure this stuff out… only have a few basic things going so far.
