Give a description of the problem
I have a GE motion sensor switch 26931 installed in my guest bath. I have it set for occupancy mode and have it turn off the lights after 5 minutes of no motion. Problem is when someone takes a shower it turns the lights off on them as it can’t see motion in the shower. -
What is the expected behaviour?
What I am trying to figure out is how to have it not turn the lights off if no motion is detected but another switch (shower fan) is on. Any ideas or example pistons?
GE motion sensor switch 26931 do not turn off if another switch is on
psnell
eibyer
Looks like you’re using the switch’s built in feature. If you want to use another switch’s status as a condition then you’ll have to do occupancy mode also in webcore.
