I have two GE ZWave Plus on.off switches. Both are the same exact version and firmware according the the SmartThings IDE. I’m using a custom device handler that exposes the double tap functionality. For switch A, my Webcore piston functions exactly as it should. However, for Switch B, the piston does not fire when the switch is double tapped. Another interesting data point is that for Switch B when configuring the piston it shows 32 available buttons instead of the two I expect. Switch A only shows 2 buttons.
Double Tapping the switch should execute the piston
