I have a number of blinds running connected with the same device, a Zipato Micro Module Motor Controller. Essentially, it is a rebranded Philio Roller Shutter Controller (PHI_PAN08-1B-525). Now these devices are working nicely, on the whole… But they have this quirk where they do not show the exact Level - rather they update the level as the blind passes every “10% mark”… E.g. if the blind is at 0% and you wanted to take it to 43%, then on the app, when it settles, it will show you 40%. If the starting point is 70% and you take it to 43%, when it settles the app will show you 50% - even though on both occasions it would have actually stopped at 43%.
It’s a bit of an issue as I have 8 blinds on the ground floor, floor to ceiling - these are zebra blinds and I keep them at 1% which gives a perfect zerba effect, but they show as 0% all the time - which means I am unable to actually move the slider to 0% on the app. Consequently, I wrote 2 pistons: one to refresh the Level from the device from WebCoRE (can’t do it from DTH as it is a stock DTH), and another piston to refresh every blind where the level is a round number, meaning that possibly its Level is incorrect and is just what the device reported to ST. The latter piston is necessary because sometimes the device does not even report there was a movement. E.g. if the blinds are at 0% and I take them all to 1%, literally none of them will register a change in Level at any point and the first piston that is subscribed to Level change events never fires…
The question I have is about the second piston - a fairly simple one, but I am a beginner and seeking to optimise stuff as much as possible and check whether i can do things in a simpler way.
My 3 questions are:
Is there any way to say “If $device.level = 0%, 10%, 20%, 30%, 40%, 50%, 60%, 70%, 80%, 90%, or 100%” all on the same line? Or do I have to construct the cindition in this long-winded manner?
Why is -
Is there any other way of capturing an event happening on a blind, other than looking at whether the level changed?
I am aware that the maximum a piston can run for is 20 seconds, however device refreshes sometimes take notoriously long and I have 15 such blinds. most take half a second, but you find the occasional one that takes rather long (e.g. 3 seconds). What would happen in this case? Would the piston be abandoned halfway through?
As you can see I split the log into 2 lines… I tried joining them in an Expression, but couldn’t (I tried using $device.location, but that would not work). Is there a way to join these on one line, to make it more human readable?
3/11/2021, 3:30:08 PM +101ms
+1ms ╔Received event [Home].time = 1615473008232 with a delay of -131ms
+73ms ║RunTime Analysis CS > 26ms > PS > 8ms > PE > 39ms > CE
+76ms ║Runtime (44422 bytes) successfully initialized in 8ms (v0.3.113.20210203) (75ms)
+77ms ║╔Execution stage started
+99ms ║║Comparison (integer) 1 is_equal_to (integer) 0 = false (1ms)
+100ms ║║Cancelling condition #6’s schedules…
+101ms ║║Condition #6 evaluated false (11ms)
+110ms ║║Comparison (integer) 1 is_equal_to (integer) 10 = false (2ms)
+112ms ║║Condition #22 evaluated false (9ms)
+120ms ║║Comparison (integer) 1 is_equal_to (integer) 20 = false (1ms)
+122ms ║║Condition #23 evaluated false (9ms)
+129ms ║║Comparison (integer) 1 is_equal_to (integer) 30 = false (1ms)
+131ms ║║Condition #24 evaluated false (8ms)
+139ms ║║Comparison (integer) 1 is_equal_to (integer) 40 = false (1ms)
+141ms ║║Condition #25 evaluated false (9ms)
+150ms ║║Comparison (integer) 1 is_equal_to (integer) 50 = false (2ms)
+152ms ║║Condition #26 evaluated false (10ms)
+160ms ║║Comparison (integer) 1 is_equal_to (integer) 60 = false (2ms)
+161ms ║║Condition #27 evaluated false (8ms)
+170ms ║║Comparison (integer) 1 is_equal_to (integer) 70 = false (2ms)
+172ms ║║Condition #28 evaluated false (9ms)
+180ms ║║Comparison (integer) 1 is_equal_to (integer) 80 = false (2ms)
+182ms ║║Condition #29 evaluated false (9ms)
+190ms ║║Comparison (integer) 1 is_equal_to (integer) 90 = false (1ms)
+192ms ║║Condition #30 evaluated false (8ms)
+200ms ║║Comparison (integer) 1 is_equal_to (integer) 100 = false (1ms)
+201ms ║║Condition #31 evaluated false (8ms)
+203ms ║║Cancelling condition #5’s schedules…
+203ms ║║Condition group #5 evaluated false (state changed) (113ms)
+206ms ║║Cancelling statement #7’s schedules…
+214ms ║║Calculating (string) Blind level of + (string) Living Room Blind 7 >> (string) Blind level of Living Room Blind 7
+216ms ║║Calculating (string) Blind level of Living Room Blind 7 + (string) is: >> (string) Blind level of Living Room Blind 7 is:
+220ms ║║Blind level of Living Room Blind 7 is:
+221ms ║║Executed virtual command [Living Room Blind 7].log (1ms)
+230ms ║║1
+231ms ║║Executed virtual command [Living Room Blind 7].log (1ms)
+245ms ║║Comparison (integer) 0 is_equal_to (integer) 0 = true (1ms)
+246ms ║║Cancelling condition #6’s schedules…
+247ms ║║Condition #6 evaluated true (10ms)
+248ms ║║Cancelling condition #5’s schedules…
+249ms ║║Condition group #5 evaluated true (state changed) (13ms)
+251ms ║║Cancelling statement #32’s schedules…
+259ms ║║Calculating (string) Blind level of + (string) Main Bedroom Blind 1 >> (string) Blind level of Main Bedroom Blind 1
+262ms ║║Calculating (string) Blind level of Main Bedroom Blind 1 + (string) is: >> (string) Blind level of Main Bedroom Blind 1 is:
+266ms ║║Blind level of Main Bedroom Blind 1 is:
+267ms ║║Executed virtual command [Main Bedroom Blind 1].log (2ms)
+277ms ║║0
+278ms ║║Executed virtual command [Main Bedroom Blind 1].log (1ms)
+1515ms ║║Executed physical command [Main Bedroom Blind 1].refresh() (1236ms)
+1516ms ║║Executed [Main Bedroom Blind 1].refresh (1237ms)
+1529ms ║║Comparison (integer) 0 is_equal_to (integer) 0 = true (1ms)
+1531ms ║║Condition #6 evaluated true (9ms)
+1532ms ║║Condition group #5 evaluated true (state did not change) (11ms)
+1534ms ║║Cancelling statement #32’s schedules…
+1542ms ║║Calculating (string) Blind level of + (string) Main Bedroom Blind 2 >> (string) Blind level of Main Bedroom Blind 2
+1545ms ║║Calculating (string) Blind level of Main Bedroom Blind 2 + (string) is: >> (string) Blind level of Main Bedroom Blind 2 is:
+1549ms ║║Blind level of Main Bedroom Blind 2 is:
+1550ms ║║Executed virtual command [Main Bedroom Blind 2].log (2ms)
+1560ms ║║0
+1561ms ║║Executed virtual command [Main Bedroom Blind 2].log (1ms)
+1575ms ║║Executed physical command [Main Bedroom Blind 2].refresh() (12ms)
+1576ms ║║Executed [Main Bedroom Blind 2].refresh (14ms)
+1590ms ║║Comparison (integer) 0 is_equal_to (integer) 0 = true (1ms)
+1591ms ║║Condition #6 evaluated true (9ms)
+1592ms ║║Condition group #5 evaluated true (state did not change) (11ms)
+1595ms ║║Cancelling statement #32’s schedules…
+1603ms ║║Calculating (string) Blind level of + (string) Main Bedroom Blind 3 >> (string) Blind level of Main Bedroom Blind 3
+1606ms ║║Calculating (string) Blind level of Main Bedroom Blind 3 + (string) is: >> (string) Blind level of Main Bedroom Blind 3 is:
+1610ms ║║Blind level of Main Bedroom Blind 3 is:
+1611ms ║║Executed virtual command [Main Bedroom Blind 3].log (1ms)
+1621ms ║║0
+1622ms ║║Executed virtual command [Main Bedroom Blind 3].log (2ms)
+1635ms ║║Executed physical command [Main Bedroom Blind 3].refresh() (11ms)
+1636ms ║║Executed [Main Bedroom Blind 3].refresh (13ms)
+1640ms ║╚Execution stage complete. (1563ms)
+1642ms ║Setting up scheduled job for Thu, Mar 11 2021 @ 3:31:08 PM CET (in 58s)
+1650ms ╚Event processed successfully (1649ms)
