Trying to create the ability to control my AC Zones using ST simulated switches. I am able to query and update the status of my AC unit using Web requests.
The HTTP GET returns the following…
[data:[default_name:Air Conditioner Settings, device_type:airconditioner, did:4, gid:0, has_state:0, has_subdevice_count:0, has_time_series:0, is_actuator:1, is_sensor:1, is_silent:0, last_data:
[DA:[amOn:false, enabledZones:[0, 0, 0, 0, 1, 0, 0, 0], fanSpeed:2, mode:0, tempTarget:22.0], timestamp:1636010784650]
, meta:[:], node:ACONNECT6827193EA581, shortName:Air Conditioner Settings, subDevices:[:], tags:aircon, vid:2], error:null, id:0, result:1]
I want to pull the 8 numbers from enabledZones:[#,#,#,#,#,#,#,#] which can be either 0 or 1 and store them in variables.
I want to be able to modify only one zone leaving the remaining 7 zones in in their existing state.
‘{ “DA”: { “enabledZones”:[Zone1,Zone2,Zone3,Zone4,Zone5,Zone6,Zone7,Zone8] } }’
Using a HTTP Put will change all zones
EXAMPLE - This will turn on Zone 5 but turn off all other Zones:
‘{ “DA”: { “enabledZones”:[0,0,0,0,1,0,0,0] } }’
N/A
