I’m migrating from ST to HE and have a number of pistons which perform a get on a local ip address on the same network as the hub. Below is an example of one piston which checks whether a NAS is running taken from ST to show the $response variable.
The get is performed on an IP e.g 192.168.1.1
The same piston on HE fails to return $response, and I suspect is not even managing to make the call out.
I’ve confirmed the HE hub can ping the address. The following error is returned in the HRE logs
app:682022-08-26 12:20:00.991 am debugReleased Lock and exiting
app:682022-08-26 12:20:00.988 am debugExiting
app:682022-08-26 12:20:00.945 am info ║║ $response=*
app:682022-08-26 12:20:00.878 am errorhttp Response Status: 408 error Message: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
The piston log contains the following
26/08/2022, 00:20:00 +901ms
+2ms ╔Received event [Home].wc_async_reply = httpRequest with a delay of 24ms, canQueue: false, calledMyself: true
+6ms ║RunTime initialize > 5 LockT > 0ms > r9T > 2ms > pistonT > 1ms (first state access 3 3 2)
+8ms ║Runtime (6449 bytes) initialized in 2ms (v0.3.114.20220822_HE)
+26ms ║╔Execution stage started
+34ms ║║Executed virtual command setVariable (1ms)
+38ms ║║Calculating (string)$response= + (string) >> (string)$response=
+39ms ║║Calculating (string)$response= + (string)* >> (string)$response=*
+42ms ║║$response=*
+44ms ║║Executed virtual command log (3ms)
+48ms ║║Comparison (dynamic) null is_not (string) [:] = true (1ms)
+49ms ║║Condition #6 evaluated true (3ms)
+50ms ║║Condition group #5 evaluated true (condition did not change) (5ms)
+55ms ║║Skipped execution of physical command [Start NAS-314].on([]) because it would make no change to the device. (2ms)
+56ms ║║Executed [Start NAS-314].on (2ms)
+61ms ║║Executed virtual command [Start NAS-314].setVariable (1ms)
+65ms ║╚Execution stage complete. (39ms)
+68ms ╚Event processed successfully (66ms)
26/08/2022, 00:20:00 +877ms
+3ms ╔Received event [Home].wc_async_reply = httpRequest with a delay of 0ms, canQueue: true, calledMyself: false
+5ms ╚Event queued (3ms)
26/08/2022, 00:20:00 +803ms
+4ms ╔Received event [Home].execute = :7bc150e5a57d1ea8be13be7db6ab459b: with a delay of 15ms, canQueue: true, calledMyself: false
+13ms ║RunTime initialize > 12 LockT > 1ms > r9T > 2ms > pistonT > 1ms (first state access 9 5 7)
+16ms ║Runtime (6440 bytes) initialized in 2ms (v0.3.114.20220822_HE)
+18ms ║╔Execution stage started
+26ms ║║Sending asynchttpGet web request to: 192.168.0.7
+28ms ║║Executed virtual command httpRequest (3ms)
+31ms ║║Requesting wake up at Fri, Aug 26 2022 @ 12:20:24 AM BST (in 23999ms) for 1 (st:2)
+38ms ║╚Execution stage complete. (21ms)
+64ms ║Setting up scheduled job for Fri, Aug 26 2022 @ 12:20:24 AM BST (in 24018ms)
+66ms ╚Event processed successfully (63ms)
Clear Full
