Creating a Get request, but no option visible to make it With JSON
Some option available to chose JSON
You trying to return json that gives a drive time in seconds from google maps API?
For google maps api, that would be:
$timeInSeconds = $response.rows[0].elements[0].duration_in_traffic.value
URL to request would look something like:
https://maps.googleapis.com/maps/api/distancematrix/json?departure_time=now&origins={origin_address}&destinations={destination_address}&key={api_key}
^^ Obviously you’d need variables for “origin_address”, “destination_address”, and “api_key”
So, looking at other examples, users would have a GET URL with JSON (at the end). Is that not need anymore?
Specifically, that configuration was possible in the past but it was misrepresentative. The “type JSON” there is supposed to show the format that would be used if you send variables along with the request. For a POST request, your variables would be encoded as {"key1":"value1","key2","value2"}. However, JSON parameters have never been supported or made much sense for GET requests since probably 99% of GET web requests will use form encoding (?key1=value1&key2=value2). Changing it from FORM to JSON had no effect so that field was removed. The server determines what response format to send.
