Get a value from actiontiles/smartthings.
I have a thermostat installed in ST and action tiles. IS there a possibility to get the value that i select in Actiontiles/ST?
I want to build a virtual thermostat. When i insert/select “20” degrees in ST, the webcore piston could get the “20” value. Is that possible?
Or if i select heat/cool/vent the piston can read that value and them activate.
(UPLOAD YOUR IMAGE HERE)
